The time now is Fri Mar 29, 2024 10:46 am
Civ3 Reorderer
¥R_M0dd€r
PostPosted: Mon Jan 12, 2015 7:53 pm    Post subject:  Civ3 Reorderer Reply with quote  Mark this post and the followings unread
I read multiple times people mentioning how time consuming it is to convert a Civ3 unit to Ra2 due to the manual file renaming of each frame. So here is a small program that does it for you.
Require Java8
CIV3 Reorderer.zip
 Filename:  CIV3 Reorderer.zip
 Filesize:  351.77 KB
 Downloaded:  18 Time(s)
[ Time: 0.1418s ][ Queries: 13 (0.0091s) ][ Debug on ]
