The time now is Thu Mar 28, 2024 11:49 pm
ccmix, a command line mix creator
Post new topic   Reply to topic Page 2 of 2 [56 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: Previous 1, 2
Askeladd
PostPosted: Sat Jan 02, 2016 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I created a small patch to repack unidentified files easily.
The filenames of unidentified files will be used as the internal ID without being re-hashed. Unidentified filenames are detected if their name is exactly 8 characters long and does not contain a dot ('.').
Turns out ccmix already supported this but you had to add "[id]" in front of the filename and I thought that was annoying and unneeded.
unidentified-repack.zip
 Filename:  unidentified-repack.zip
 Filesize:  1.11 KB
 Downloaded:  127 Time(s)
PostPosted: Sat Jan 02, 2016 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I expect the patch won't be all that useful to most people as I doubt many windows users take the time to build software from source. You should also change the code that extracts unidentified files as well and change the comment that describes how isIdName() works. Then again I guess most people will extract with XCC.
PostPosted: Sun Feb 12, 2017 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there any documentation for this tool? Also are you still working on it?
PostPosted: Mon Feb 13, 2017 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Documentation is on the github for the project. I'm not currently working on it as it does what i want it to do already, but if anyone wants to add features and send a pull request I will merge the code.
PostPosted: Mon Feb 13, 2017 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Mon Feb 13, 2017 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Warning, game type is td but header is new format." When I try extract from mix file giving this error, How can I fix thath.
Post new topic   Reply to topic Page 2 of 2 [56 Posts] Goto page: Previous 1, 2
[ Time: 0.1520s ][ Queries: 13 (0.0122s) ][ Debug on ]
