The time now is Thu Apr 18, 2024 2:51 pm
Adding new features(tags) to OpenRA
Moderators: Global Moderators, OpenRA Moderators
Post new topic   Reply to topic Page 1 of 1 [9 Posts] Mark the topic unread ::  View previous topic :: View next topic
¥R_M0dd€r
PostPosted: Tue Aug 05, 2014 3:59 pm    Post subject:  Adding new features(tags) to OpenRA Reply with quote  Mark this post and the followings unread
I want to add a new tag to Warheads called Stun, for testing and education purposes.
BarrelExplode:
   Warhead:
      Stun: 300
      Damage: 500
      Spread: 426
The units(I guess its called "Actor" in OpenRA?) hit by this warhead are unable to move for 300 frames(or whatever measurement system OpenRA uses).
I am not looking for someone to write the code for me.
I was wondering if there are tutorials around explaning the source code. An API? Also some tips on which classes and interfaces I should look at in order to implement this.
How can I make the parser read and understand the Stun tag?
PostPosted: Tue Aug 05, 2014 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's C# as I understand. I know some java and have looked at the source code a bit, but you're going to need more than a simple tutorial.
deniz1a
PostPosted: Tue Aug 05, 2014 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
luxycomplex
PostPosted: Tue Aug 05, 2014 11:04 pm    Post subject:  Welcome to the party Reply with quote  Mark this post and the followings unread
"Welcome! Thanks for joining us. here at ppmsite, deniz1a..."
Glukv48
PostPosted: Wed Aug 06, 2014 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias M.
Stealth Laser Trooper
PostPosted: Sat Aug 09, 2014 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
You can create new warheads with custom effects at https://github.com/OpenRA/OpenRA/tree/bleed/OpenRA.Mods.RA/Warheads since the recent refactor.
The IDisable interface which is currently used for powering down buildings may be a starting point https://github.com/OpenRA/OpenRA/blob/bleed/OpenRA.Game/Traits/TraitsInterfaces.cs#L115 that needs to be generalized further or the ISpeedModifier https://github.com/OpenRA/OpenRA/blob/bleed/OpenRA.Game/Traits/TraitsInterfaces.cs#L159 assuming you just set movement speed to 0 while stunned to disable unit movement temporarily.
Anyway, the first thing to do is file a feature request at https://github.com/OpenRA/OpenRA/issues/new so we don't lose an overview and reach more interested developers.
PostPosted: Sat Aug 09, 2014 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias M.
Not much of a point of ¥R_M0dd€r feature request as the OpenRA team is going to need to do this anyway for the TibSun port to OpenRA. What ¥R_M0dd€r is trying to is make the TibSun EMP effect that shuts down tanks and cycborgs.
Matthias M.
PostPosted: Sat Aug 09, 2014 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
alieen
PostPosted: Thu Dec 04, 2014 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
emma
[ Time: 0.1498s ][ Queries: 11 (0.0084s) ][ Debug on ]
