The time now is Fri Mar 29, 2024 1:57 am
Allied & Nod Turrets
Madin
Plasma Trooper
PostPosted: Sun Oct 06, 2013 3:18 am    Post subject:  Allied & Nod Turrets Reply with quote  Mark this post and the followings unread
Madin's Turrets
Files include all necessary XML, W3X, and texture files needed for editing and compilation.
Contains both Allied & Nod Turrets.
Ready to use!
It is assumed that you have the C&C3 mod sdk and have been able to at least compile the sample mod. Check the included read me for permissions.
The format that I've packed the files in means that they are ready-to-compile, no XML work is needed at all.
You are expected to adjust the code to your needs, all I have added are the basics. Balance and fine tuning are up to you.
This uses Lauren's 'ObjectGenericHC.fx' shader file, which has been included in locations correct for both users of Bibber's RA3 based mod tools or those who still use the classic buildmod.bat.
One is coded to replace the GDI guardian cannon, but of course you can use it how you please.
The other is coded to replace the Nod Laser Turret, but of course you can use it how you please.
Includes an upgrade  (for the Nod Turret) which can be found in the Nod Operations Center.
Includes an alternate version which more closely matches the C&C3; Nod colouring.
You may re-distribute this package as long as all initial files, including this Read me and all uncompiled files, are included.
You may freely use, modify and improve all the graphical assets for any public mod as long as you give proper credits and it is not for any profit.
Primary credit: Madin (Model + Texture)
Secondary credit: Lauren (ObjectGenricHC.fx shader)
Public asset declaration
Ready to use: Yes
Sides: GDI & Nod
Portrait & Buttons: Yes
Shader: ObjectGenricHC
Build up animation: Yes
Damage textures: Yes
Damage 2 state: Yes
Destruction animation: Yes
 Filesize:  473.26 KB
 Viewed:  3820 Time(s)
MadinTurrets.zip
Now contains both Nod and Allied versions!
 Filename:  MadinTurrets.zip
 Filesize:  7.23 MB
 Downloaded:  43 Time(s)
Madin
Plasma Trooper
PostPosted: Sat Oct 25, 2014 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added Nod turret to the package!
[ Time: 0.1141s ][ Queries: 14 (0.0086s) ][ Debug on ]
