The time now is Tue Apr 23, 2024 9:47 am
Difference
Moderators: freedom fighter
Guest_zeta A
PostPosted: Thu Sep 18, 2014 3:42 pm    Post subject:  Difference
Subject description: why factions are same???
This mode have a BIG problem!:
. factions are look like same,  all of them have same tech tree!
. All of them have same branching, each with 3 branches
so this is my idea:
ALLIES:
. airfield is no longer provides tier 2 and radar
. a new building called 'Command Hub' provides radar and tier 2 (with YR robot facility shp)
. Airfield is available after building command hub and ore refinery
. Tech Hub (new name for allied battle lab) is available after building Command Hub & Armour Facility
. After building command hub, you can install 3 upgrades (White out, bird of prey, time) on it  that grants different things and support powers
. only one upgrade can be used on each game
Note: I will ad data about other factions later
      .  they are different
Zengar_Zombolt
Plasma Trooper
PostPosted: Thu Sep 18, 2014 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
You must be new to RA2 modding. These things have been done for years, even since I got into modding about 8 years or so ago.
It's called balance, and it changes from modder to modder.
I am Zengar Zombolt, The Sword That Cleaves Evil!
There is Nothing I can not Cut!
PostPosted: Thu Sep 18, 2014 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can always do these things yourself, in your own mod Smile
[ Time: 0.1426s ][ Queries: 11 (0.0079s) ][ Debug on ]
