The time now is Fri Mar 29, 2024 5:55 am
OS SHP Builder Windows 7 Problems...
Moderators: stucuk
Post new topic   Reply to topic Page 1 of 1 [19 Posts] Mark the topic unread ::  View previous topic :: View next topic
warlock
AA Infantry
PostPosted: Mon May 27, 2013 6:25 pm    Post subject:  OS SHP Builder Windows 7 Problems... Reply with quote  Mark this post and the followings unread
Hello there... I'l like to report a small problem I got with OS SHP Builder 3.36, When I open the application it gives a strange error:
"Access Violation at address 0052F26C in module 'SHP_Builder.exe'. Write of Address 00000000."
Someone knows how to solve this problem?
View user's profile Send private message Send e-mail YouTube User URL Skype Account AIM Address
PostPosted: Mon May 27, 2013 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea. At least these words doesn't mean anything to me.
Check if the latest beta still has this problem.
PostPosted: Tue May 28, 2013 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Access Violation?
Maybe an admin issue like not having enough rights to run the application.
warlock
AA Infantry
PostPosted: Tue May 28, 2013 9:21 am    Post subject: About SHP Builder Reply with quote  Mark this post and the followings unread
Thanks Banshee (Ou devo dizer valeu Banshee)... The new one you put here to install works perfectly... Doesn't give any problems... Very Happy
PostPosted: Tue May 28, 2013 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome (de nada Wink).
warlock
AA Infantry
PostPosted: Fri Jun 20, 2014 7:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I found a new problem... My OS SHP Builder keeps corrupting every .shp file... Damaging frames, less the first, how can I solve it?
PostPosted: Fri Jun 20, 2014 10:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you using the latest version (3.38 beta 6)? And what kind of .SHP files is it messing up with? TD or TS ones? And finally, are you trying to save these files inside Program Files or some kind of protected directory (Windows 7 might be a pain in the ass with these things)?
PostPosted: Sat Jun 21, 2014 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Since I have similar issues, I'll answer as well.
Yes.
TD definitely (XCC Mixer and OpenRA crash hard on them), TS sometimes too (visual corruption of files produced by XCC Mixer, since zaaz' changes sometimes the files saved by SHP builder crash OpenRA/XCC, too).
No. All my modding stuff is located on partition E.
It should be noted that SHP Builder itself can usually re-load shps that crash OpenRA/XCC just fine, so this is most likely an issue with how SHP Builder writes the file header.
PostPosted: Sat Jun 21, 2014 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Damn. I thought Zaazs changes really fixed the issue with the SHP TD header. Can you place a sample of corrupted SHP TD file?
warlock
AA Infantry
PostPosted: Sat Jun 21, 2014 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well... Yes i'm using the newest version of OS SHP Builder, saddly I lost many of my work in .shp files because corruption...
I'll put a damaged file that I got:
techcen.shp
There's a example... Also I got similar problem with the gates there exist here on PPM (Allied, Yuri, Soviet)
 Filename:  techcen.shp
 Filesize:  51.29 KB
 Downloaded:  34 Time(s)
PostPosted: Sat Jun 21, 2014 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here. XCC Mixer crashes when trying to view it.
td-shp-test1.shp
 Filename:  td-shp-test1.shp
 Filesize:  4.5 KB
 Downloaded:  33 Time(s)
PostPosted: Sat Jun 21, 2014 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've downloaded these files. I'll take a look at them later. Right now, my priority are some things for the university which I'm bad on their deadline.
Zaaz
PostPosted: Wed Jul 02, 2014 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm going to investigate too. What I found strange when I was fidling around with XCC Mixer is that it crashed the 2-3 first times that I tried viewing the your shps, but after that I could view them without problems. hmn, idk.  Anyway, I'll try opening them in OpenRA editor and see if that crashes too. Does the editor work for TS shps too?
deathreaperz
PostPosted: Wed Jul 02, 2014 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Failed Conversion maybe?
Humans were born for two things: to pray and be productive.
Zaaz
PostPosted: Wed Jul 02, 2014 8:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Reaper, do you have steps to reproduce a corrupted shp?
I'd like them if possible.
I know that even though XCC Mixer doesnt crash on td-shp-test1.shp anymore, it still reports smth in the Windows Event Log: FaultTolerantHeap. I don't know what it is, but I'll try to check into it.
Hmn.
PostPosted: Thu Jul 03, 2014 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm, that's typical, with another shp I now couldn't reproduce it...
However, this file works with XCC Mixer and C&C95, but crashes OpenRA (with an Index out of array error).
This is probably at least partially OpenRA's fault for being less crash-proof in this regard since neither XCC nor C&C95 show any corruption or crashes with this file, however it's also a fact that OpenRA has no problems with any of WW's original shps, nor with any shps produced by XCC Mixer. So it has to be at least partially caused by something specific to files saved with SHP Builders' saving mechanism.
The file in question:
fact-388b6.shp
 Filename:  fact-388b6.shp
 Filesize:  146.86 KB
 Downloaded:  20 Time(s)
PostPosted: Thu Jul 03, 2014 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for double-posting, but now I managed to reproduce a file that crashes XCC Mixer as well.
Opened original ti2.des from C&C1, just replaced some colors via cscheme, saved as shp(td) -> XCC crashes when trying to view it.
SHP Builder itself can still load it fine.
ti2des.shp
 Filename:  ti2des.shp
 Filesize:  2.77 KB
 Downloaded:  21 Time(s)
PostPosted: Sat Jul 26, 2014 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tested all these files with XCC Mixer and it works fine. It did not crash here.
However, OpenRA fails to decode one (or more) of their frames (index out of bounds issue) and it crashes. I don't know exactly what on SHP Builder's encode80 causes OpenRA to access an invalid memory address or allocates less RAM than necessary. I'd have to debug OpenRA to try to understand the problem. And that's something that I admit that I can't be bothered to do at the moment.
PostPosted: Sun Jul 27, 2014 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
OpenRA has a condition at 2 commands from their Format80 decoding function that... for me, it doesn't really make much sense:
   if (srcIndex >= destIndex)
throw new NotImplementedException("srcIndex >= destIndex {0} {1}".F(srcIndex, destIndex))
In a certain way, it means that when a frame is not properly compressed (it is taking more space than it was supposed to take, the program closes with an exception. Of course that, in the ideal world, these frames were supposed to take less space than their uncompressed form, but programs like OS SHP Builder and even OpenRA itself (at least its code) save all frames using Format80. And that doesn't guarantee that these frames will take less space than their uncompressed form at all.
If i make OS SHP Builder save stuff with Format40 and 20, I think it would considerably slow down the program. It would need to compare the Format80 compression with Format40 using all previous frames, for each frame although we would be smart enough to make it start from the previous frame. I don't think it is worth the hassle or the gains in terms of file space for the save files.
It's better to check if these files load at OpenRA without this exception (that XCC Mixer doesn't have either).
[ Time: 0.1609s ][ Queries: 13 (0.0128s) ][ Debug on ]
