The time now is Fri Apr 19, 2024 2:12 am
Some questions about map
Post new topic   Reply to topic Page 1 of 1 [4 Posts] Mark the topic unread ::  View previous topic :: View next topic
secondwtq
PostPosted: Wed Apr 02, 2014 10:45 am    Post subject:  Some questions about map Reply with quote  Mark this post and the followings unread
I tried to add sky for C&C3, as the C&C3 New Experience mod has this content, I downloaded it source then copyed model and code of skydome then merged with my mod and added a skydome to a map. BUT in the game, the scene would be clipped at a certain distance, and the skydome just displayed incompletely because of it. So what on earth does NE do to prevent it?
And, is it possible to have KW maps used in TW? I extracted them and opened with TW WorldBuilder then got nothing except a crash.
Ju-Jin
PostPosted: Wed Apr 02, 2014 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Go to the scripts, there is one to change the camera frustum to display far away objects.
secondwtq
PostPosted: Fri Apr 04, 2014 6:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I found it called change camera depth of field, thanks!
superdjidane
Cyborg Engineer
PostPosted: Mon May 05, 2014 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
KW maps have also the subfactions AI defined. (Zocom, Steel Talons, Black Hand, Marqued of Kane, Reaper 17 and Travelers 59) Try to remove them in map editor. (I never use it till now...)
I know the TW maps works is KW, but the sub faction will do nothing...
[ Time: 3.3571s ][ Queries: 11 (3.1696s) ][ Debug on ]
