The time now is Sat Apr 20, 2024 10:10 am
TS Tiberium based features with Ares
Moderators: Ares Support Team at PPM, Global Moderators, Red Alert 2 Moderators
Post new topic   Reply to topic Page 1 of 1 [15 Posts] Mark the topic unread ::  View previous topic :: View next topic
MasterHaosis
PostPosted: Mon Nov 11, 2013 3:48 am    Post subject:  TS Tiberium based features with Ares
Subject description: What we can do and recreate from TS lifeforms and Tiberium related stuff
Hai there.
Since AlexB allowed us to use tiberium heal/damage and custom warhead, it is good start for everything else.
This is topic for here, as it depends of Ares codes mostly.
According to this
http://yellow-killer.tripod.com/id10.html
(perhaps someone who did not play TS for long time, and forgot what many things did, what is their purpose, and how to enable them as it was not possible before Ares)
How we can recreate those stuff from TS into YR using Ares, what is possible, what is not?
I do not think that there is somethin else related to tiberium life forms. if there is, mention please.
Tiberium Floater I think it can be partially recreated. We have tesla weapon for electrolyzing, virus or such gas as secondary weapon.
AlexB told me that problem is Jellyfish=yes tag assigned to Floater adds him more hardcoded stuff, thus cannot be enabled.
Tiberium Moss: I do not know what is it, maybe overlay type as Tiberium/Ore except it cannot be harvested but slows down only your units. Perhaps can be done.
Tiberium Fauna: I do not think that it works as described. I do not think that it actually attracts Ion storm. If it does, then it cannot be done here.
Tiberium Cruentus: it spread blue crystals, therefore not possible here. AlexB said that it is Fire storm only tag. TiberiumToSpawn=2 code is in question which is not present in YR
Tiberium Riparius and Vinifera They are both possible. What is even better, with Ares we can now set custom Damage/heal and warhead to tiberium types!
Veinhole Monster: Sadly, it is not possible at all.
Mutants: Now possible thanks to Tiberium Heal. Additionally, when killed, they scatter tiberium here.
Tiberium Fiend: I was told by AlexB that aside from Tiberium Heal this cannot be done, as it has Doggie=yes tag which adds several logics to it. It uses prone over tiberium and has increased panic when on red, or such...
As you can see, some are using prone in that picture when stood in tiberium.
Visceroids They are possible, at least partially as I tested. They are vehicle types which required special logic infantry to become vehicle type upon death. They wander around and travels all time constanbtly. Additionally, we can use MakeInfantry upon death to create infantry type visceroids, we have greater choice here as two different tiberiums can create two different type of units thanks to custom warheads. Also we can add isCow=yes to visceroid, so it can wander slowly wound.
Tiberium Gas: Many things release that gas in TS, but I think it is possible as we already have few type of gas too. That gas created visceroids upon death too. I do not know if that is possible or not, but thanks to make infantry logic, we can at least have infantry type visceroid.
Ion Storms: I was told by AlexB this is not possible as if enabled, in TS Ion storms appeared randomly over map. We can only use similiar via map triggers or such, partially to enable it using lighting storm SW, converting it to ION storm.
Whats your opinions?
PPM Halloween Season 2021
EricAnimeFreak
PostPosted: Mon Nov 11, 2013 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Tiberium Fauna could be done, of course, how you balance it, or decide how often it fires, or randomness of it etc, would be rather hard.
Veinhole Monster and Veins using Alex latest testing branch could be done, I think. Seeing how there are unused tiberium overlays to exploit. Basically the Monster would be a building which autofires gas and also spreads this new type of Ore Vein. The real problem would be duplicating the spreading ability, and damage to buildings.
Ion Storms as they were in TS are not possible. But a very close workaround is possible using map editing. I made MLEP originally for the purpose of recreating TS Ion Storms.
Grab my Map Logic Expansion Pack 5.2 here!
Adds random weather patterns into maps.
More disabled navalyards.
Preplaced Neutral buildings.
Additional new features.
Enjoy Everyone!
PostPosted: Mon Nov 11, 2013 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Jellyfish=yes makes it use in TS the keys under the [LEVITATION] section, which gives it together with the unique locomotor {3DC0B295-6546-11D3-80B0-00902792494C} the special random movement and attacking behaviour.
It's nothing else than a LAT (terrain like grass, clear or rough)
No need for Ares to add such a thing, you only have to replace one of the existing LATs. (Does Ares allow to add new LATs ?)
Nothing but ordinary terrain. No additional logic is applied to them in TS. They are like trees.
The key LightningRod, which makes it attract IonStorm bolts, works only on buildings in TS.
Use art.ini debris via an activeanim on a dummy building to spawn any overlay/tiberium you want. (No Ares necessary)
Use CellAnim on the tiberium overlays (without any randomizing keys on the anim in art.ini, which cause sync-losses in online games). Then you can use the anim to do any damage/healing you want even without Ares.
a combination of art.ini debris and CellAnim. Not 100% the same but at least a bit similar.
special/reserved armor for these, overlays with damaging cellanim and warhead that heals on this armor, special deathweapon with explosion using art.ini debris. (No Ares necessary, just some modding)
The additional dog logic that RA2 offers is superior to any hardcoded behaviour of doggie in TS. Simply give it prone frames as the default standing frames and you have it in RA2.
Does the RA2 "Gas" BehavesLike TS gas? Does it move around randomly too?
Anyway, the TS gas isn't very special, so it surely can be done one way or another in RA2 too.
better use an invisible dummy building, that spawns via an activeanim art.ini debris all over the map some random lightning bolts.
Then you can simply turn on/off the building and this way start/stop the IonStorm.
The building could also get a special AntiAir weapon which shoots down instantly any flying aircraft.
Further the building can get the tiled light keys, to give the map a different lighting when powered.
Done right, you then only have to place that single building to a map, and create a few triggers to randomly turn that building on and off.
PostPosted: Mon Nov 11, 2013 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
isCow= It only works for the InfantryTypes. There is a tag for VehicleTypes, this LargeVisceroid=yes
MasterHaosis
PostPosted: Mon Nov 11, 2013 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
As LKO said, it is ordinary terrain, like trees. That does not do anything.
Well, there are 4 Ore types, two are unused, although I heard that there is one which is masked as regular ore in some maps.
Yes, I saw your workaround. it is done for each map separately via triggers.
LKO, thanks for reply Very Happy I knew TS talking will bring you here haha
I did not know that Floater is that much hardcoded, AlexB for sure mentioned his special movement but did not say what exactly.
I though that it is overly type hehe.
I do not know if Ares can add new LATs, never checked it, but I do not think so.
Yes, thanks to Ares, we have that tag too on buildings.
So this can work even for blue crystals?
I saw such metod in Mental omega and few other mods where buildings spawn Tiberium but did not know that it can be used to spawn blue one.
No, CellAnims do not work as supposed. Anim is player later even if no ore is present. Additional, I heard that cell anim cause recon error.
So, for Tiberium Damage/heal, Ares is a must.
No Cell anim. But as EricAnimeFreak said, perhaps unused Tiberium type may work, while it automatically spreads toxin gas.
But then you cannot have his own death. Point is that infantry will get flamed, melted, electrolized etc etc... while still scatter tiberium upon death.
Sure that special anims work on units such as Tiberium Fiend which does not die as normal human, therefore it is possible.
And you just gave me idea!
Wait second. Does Tiberium Fiend us his prone only when standing over Tiberium? I think it is so he can camouflage there.
So, if I put default prone when standing, it will prone even in normal ground.
But I got idea for this though player controlled Tiberium Fiend can do that.
We have deploy infantry like GI or GGI, therefore we can manually deploy Fiend in Ore patch Very Happy
I do not know how gs behaves in TS, but I suppose its same, such as Virus gas.
How can bolts exactly be spawned as debris?
Well, yes we have tesla weapon already additionally we may color it, but point is, if it is weapon, then it must fire only from some point such is its FLH. But partially it can be solved with Alternate FLHs as masterMind has those.
That means triggers are still a must.
Yes, I know,  I was referring to infantry type visceroid.
Also, SmallVisceroid=yes also creates similiar effect on vehicle type.
PostPosted: Mon Nov 11, 2013 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Create an anim of a bolt, then use it as the explosion of the debris.
They are a must in TS as well. Without doing any work, you also don't have any Ion Storms in TS.
4StarGeneral
PostPosted: Mon Nov 11, 2013 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Veinholes are possible, they just can't grow in a normal way. I used to have them working with debris, gattling logic to fire far and near (heavy guess work to be done), and AreaFire, creating overlays through some creative means.
I suppose one might be able to expand upon that now with AnimToInfantry and build further expanding veins that expand more precisely and cleaner, almost TS-like.
Still vein harvesting logic is impossible though AFAIK. Though Ares might expand upon it eventually.
SMIFFGIG
PostPosted: Mon Nov 11, 2013 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could always post this in a bit more detail to updated my Tiberium Twinkle tutorial in the tutorial forum.
I didnt know there was a solution to this problem Smile
PostPosted: Mon Nov 11, 2013 9:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bittah and me did that already Wink
see my first post in (**) Tiberium Twinkle Smile
RandomLoopDelay is the culprit.
MasterHaosis
PostPosted: Thu Nov 14, 2013 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa Lin Kuei! Did you made that effect or it is stock TS Bolt anim?
Wait. TS I0on Storms all time are done in each map?
I though they are by random definied in rule.ini and they automatically fire in each map.
So they should be set in each map separately?
LKO gave best idea, anim which spawns overlay. And you seem also to give some ideas.
Does anyone have voinehole example somewhere?
I have never seen that in YR mod.
Lin KUei Ominae, how does veinhole attack exactly? I know that it spreads gas but does it spread automatically at target when in it's range, or simply gas randomly appears from it's center and floats around?
How can be used anim to infantry?
Yes, Veinhole Harvest logic cannot be done. Why for veins were used, for some superweapon?
PostPosted: Thu Nov 14, 2013 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
The stock lighting bolt in TS looks nothing like that, so he must've made it (his version might actually look a bit better than the stock lighting bolt).
Ion Storms can only be started via map triggers, yes.
The veins will simply start attacking any unit that's standing (or moving) right on top of it, unless the unit has ImmuneToVeins=yes. The attack is just an SHP animation which keeps repeating for as long as a unit is standing on the cell, which gradually damages it.
The veinhole monster itself also has sort of an attack, although it can't actually target anything. It start spawning gas clouds whenever it gets attacked by anything and these gas clouds just drift off into random directions, like gas clouds normally do in TS.
They're used to charge Nod's chemical missile.
4StarGeneral
PostPosted: Fri Nov 15, 2013 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
AnimToInfantry, and those infantry areafire with selfdamaging weapons that spawn overlays and spawn more infantry, thus expanding, obviously adding a large delay to each weapon, etc.
MasterHaosis
PostPosted: Fri Nov 15, 2013 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Guys, but I planned to create veinhole monster as SHP Building, which has anim which spawns out overlay type. One unused tiberium type actually which looks like veins. Monster would have some weapon actually which spreads out gas clouds at enemies.
But I have question cause I haven-t tried that yet.
Can any overlay type be used for spawn, or it must be just tiberium type?
If I use unused tiberium type can it be made unharvestable?
MasterHaosis
PostPosted: Thu Nov 21, 2013 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah LKO, few nights ago AlexB told me that Jellyfish=yes has nothing to do with locomotor. He said that it disables some checks and adds specific wandering and attacking behavior.
MasterHaosis
PostPosted: Wed Jan 01, 2014 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
And now Jellyfish is possible with Attach Effect! Very Happy
Thanks to Graion Dilach, who was helpful, I managed to mimic Floater, so it can can fire its weapon and release gas cloud in same time. Only difference than in TS it is doing that while moving, here all time releasing each cloud by some period (which is even better)
[ Time: 0.1870s ][ Queries: 11 (0.0097s) ][ Debug on ]
