The time now is Fri Apr 19, 2024 2:43 pm
[YR] Atom Heart (2-8)
Post new topic   Reply to topic Page 1 of 1 [14 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Fri Jun 07, 2013 12:25 am    Post subject:  [YR] Atom Heart (2-8) Reply with quote  Mark this post and the followings unread
Here's a new symmetrical map I just made, would've been a better entry for CCC3 but hey-ho. Below is the preview, note the crates on the cliffs are actually invisible ingame and used to prevent base construction in those places.
(click for full preview: 3MB)
If you notice any issues tell me here!
ob_atomh8p.zip
 Filename:  ob_atomh8p.zip
 Filesize:  229.88 KB
 Downloaded:  472 Time(s)
DaRkGlAcEoN
PostPosted: Fri Jun 07, 2013 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks Nice OmegaBolt, I'll give the map a shot.
You can call me Dark or Glace/Glaceon if my name is annoying to type.
4StarGeneral wrote:
I CAN USE CAPS TOO, HOW DOES IT FEEL?
PostPosted: Fri Jun 07, 2013 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
OmegaBolt maps are always sweeetness. I can't wait to play on it. Smile
DaRkGlAcEoN
PostPosted: Fri Jun 07, 2013 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I've always loved his maps. Very Happy
DaRTzO
PostPosted: Fri Jun 07, 2013 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Too many tech structures, otherwise a nice map.
RP
PostPosted: Fri Jun 07, 2013 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Totally disagreeing with you there, it gives you something to fight over.
Did you notice this is an 8 player map, not 2 player?
Nice map, Bolt!
(What's with the palets?)
Mental Omega 3.0 Mission creator - Creator of FinalOmega: APYR 3.0 Map Editor
/ppm/'s stupidity
PostPosted: Fri Jun 07, 2013 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I don't quite understand the significance of the palettes. Is it to prevent structures being built there?
PostPosted: Fri Jun 07, 2013 3:08 pm    Post subject: Re: Atom Heart (2-8) [YR] Reply with quote  Mark this post and the followings unread
I'm sure RP was trolling but Aro? You just didn't read. #Tongue
OmegaBolt wrote:
note those 'palet's on the cliffs are actually invisible ingame and used to prevent base construction
And yes there are a lot of Tech buildings. I didn't want to go crazy and yet, as RP said, wanted something to fight over, especially in the middle. I think especially in teams of 2 they're all necessary things to capture and hold and in 4v4 there's enough for each team member.
Zero18
PostPosted: Fri Jun 07, 2013 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Details 10/10: I love how symmetrically this map is. Not so many symmetric maps out there nowadays. I can see why you called this map Atom Heart.
Layout: 10/10: The layout is very nice, especially this is symmetric map. I like how you make the starting position little more unique with cirle with triangle edges. Smart usage of tech structures placements and resource fields. I have to say this is probably the most balanced layout I've seen.
Lighting: 9/10: Not much to say for the lighting. But hey, it fits nicely into the map.
Gameplay: 10/10: I just dueled with other 7 Brutal AIs and owned them. Like as I said before in the Layout part, the resource fields are balanced and distributed evenly between each player base. I even take tech structures as well too. To be honset, this might make a great player vs player map as well too.
Triggers/Effects 5/10: Only 1 trigger was performed, sound. It kind of makes the game little dull if there is no other triggers to make it more interesting. But you did good job.
Overall 44/50: Nice job! Someone please spotlight this map! Or I will come and hunt after them and make them do it!
Mod Leader and founder of World Domination
PostPosted: Fri Jun 07, 2013 3:10 pm    Post subject: Re: Atom Heart (2-8) [YR] Reply with quote  Mark this post and the followings unread
It's official. I have lost the plot.
Nice map by the way, you should have indeed submitted it.
PostPosted: Fri Jun 07, 2013 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are there no transition pieces? Those clearly visible tiles around the Ore fields look horrible imo.
PostPosted: Fri Jun 07, 2013 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, thanks for the review Zero! Regarding map lighting, it should all get a bit more interesting when the Tech buildings are captured as they emit light (though subtly). An issue I've noticed is the top left middle player's base isn't aligned with the guy below him. Will probably post a fixed version if there aren't any more issues/comments.
Not sure what else would be needed. Suppose I could've made the 'city' in the middle more alive but the map felt quite 'heavy' ingame anyway so didn't want to reduce performance with more stuff. Maybe I could add some annoying police cars driving around. #Tongue
No there arent, sadly. Only straight diagonal 'transitions', like with the grass.
PostPosted: Fri Jun 07, 2013 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't like the repetition of the buildings in the middle, but apart from that I like this map.
PostPosted: Thu Oct 03, 2013 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Uploaded the download with the last version I did. Don't remember the exact fixes but it moved the start positions so they weren't so out of sync.
[ Time: 0.1791s ][ Queries: 13 (0.0091s) ][ Debug on ]
