The time now is Thu Apr 18, 2024 9:39 pm
XCC Aud Writer Plug-in
Post new topic   Reply to topic Page 1 of 1 [15 Posts] Mark the topic unread ::  View previous topic :: View next topic
DarkVen9109
PostPosted: Fri Jul 12, 2013 10:12 am    Post subject:  XCC Aud Writer Plug-in Reply with quote  Mark this post and the followings unread
I need help on where to find the out_aud.dll plug-in because I always encounter that error. -__-
tomsons26lv
PostPosted: Fri Jul 12, 2013 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Tiberian Dawn, Red Alert, Tiberian Sun ,Red Alert 2,Renegade, Command & Conquer 3,Tiberium and Tiberium Wars and Westwood related image & video archive
https://picasaweb.google.com/113361105083292812413?noredirect=1
Skype live:tomsons26
Don't forget to state who are you otherwise i'll ignore the invite
DarkVen9109
PostPosted: Sat Jul 13, 2013 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
No I mean how can anyone help me fix that annoying error. I have the Aud writer
PostPosted: Sat Jul 13, 2013 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
"that annoying error"?
You need to reformat your hard disc. :V
DarkVen9109
PostPosted: Sun Jul 14, 2013 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Gosh. Is it the only way to solve that annoying error Orac?
PostPosted: Sun Jul 14, 2013 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
What's your issue tbh?
I don't have my crystal ball and your error desciption is wonderful.
DarkVen9109
PostPosted: Sun Jul 14, 2013 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Whenever I try to install it it says that out_aud.dll is missing and I googled it and I found nothing.
PostPosted: Mon Jul 15, 2013 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
http://xhp.xwis.net/utilities/XCC_AUD_Writer.zip
Tested it out and works fine so DarkVen9109, you have to be more specific on your problem... the exe inside is a mere installer that copies in out_aud.dll in winamp plugins folder.
One chance is incomplete download but zip extract should have whined or you have some windows rights management issue blocking it.
Else, you could just use Xcc mixer make the auds from the wavs.
DarkVen9109
PostPosted: Thu Aug 22, 2013 7:33 am    Post subject:  XCC Aud Writer Plug-in HELP!! Reply with quote  Mark this post and the followings unread
Bumping
OK. As I have tried it numerous times again failed... I don't literally understand why but my installation is correct, IIRC I started installing this via USB but I believe it might be a possible reason why.
Added an Attachment as a proof
This annoying error... -___-
 Filesize:  32.62 KB
 Viewed:  4571 Time(s)
PostPosted: Thu Aug 22, 2013 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks a lot like write protection
If it doesn't works there, why don't you simply choose another folder, e.g. the temp folder which always has write permission. (or some other folder which isn't inside a protected system folder)
Then copy the extracted dll from the temp folder into your winamp\plugins folder manually.
look at the error message. It says it can't write the file, not it's missing. Give correct error messages and descriptions of what you did wrong. As GD said, we don't have a crystal ball to see what you did.
Laughing
DarkVen9109
PostPosted: Thu Aug 22, 2013 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Masters GD and LKO. Here's what I did, I downloaded first winamp and the XCC AUD writer in the internet cafe, then by the time I got home, I installed win amp via USB. That's just what I did IIRC.
PostPosted: Thu Aug 22, 2013 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
[...]Winamp\\Plugins[...]
Check Winamp's settings about where it searches the plugin itself... that one is a really bad typo.
PostPosted: Thu Aug 22, 2013 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
additional backslashs are no problem
You can write as many as you want in console and other paths. Usually the system removes redundant ones.
PostPosted: Thu Aug 22, 2013 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
That's program-dependant, LKO, some does, most doesn't.
And when I've had such in Winamp at the CD ripping output path, Winamp couldn't save the files.
PostPosted: Thu Aug 22, 2013 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
And sometimes they read it as being an additional directory layer, breaking the operation.
[ Time: 0.1813s ][ Queries: 14 (0.0100s) ][ Debug on ]
