The time now is Fri Apr 19, 2024 8:50 am
ROS_XXX maps Corrupts by FinalAlert 2 Yuri's Revenge
Moderators: Holy_Master
luxycomplex
PostPosted: Sun Nov 18, 2012 2:47 pm    Post subject:  ROS_XXX maps Corrupts by FinalAlert 2 Yuri's Revenge
Subject description: FA2YR claims ROS_XXX maps corrupts!!!
I have problem to edit map from this mod. Final Alert YR Map editor always give error message each time I open ROS_XXX maps. It says the map seems to be corrupt. I have put desertmd.ini into editor's folder. Any one can help please..? Confused Question
PostPosted: Sun Nov 18, 2012 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Desertmd.ini should probably be in the ROS folder as FA2 tends not to read inside many mixes. Also might want rulesmd and artmd in there too so it reads new units and their art.
luxycomplex
PostPosted: Sun Nov 18, 2012 4:08 pm    Post subject:  Putting desertmd.ini into ROS folder solves problem.. Reply with quote  Mark this post and the followings unread
I don't believe it... It's works.. heaven.. oh.. boy. as simple as that.. actually I have these problem haunting me for days..I just forget to ask for the solution in these forum.. thanks man.. Experienced persons always helpful..indeed... Very Happy Laughing
This mod has very cool models.. Cool
[ Time: 0.1690s ][ Queries: 11 (0.0068s) ][ Debug on ]
