The time now is Wed Apr 24, 2024 3:14 pm
Any Programmers out here?
Post new topic   Reply to topic Page 1 of 1 [26 Posts] Mark the topic unread ::  View previous topic :: View next topic
Stealth Killer
PostPosted: Thu Mar 10, 2011 6:35 pm    Post subject:  Any Programmers out here? Reply with quote  Mark this post and the followings unread
How can we code a simple program in Borland Delphi to read and write MIX files. The Mix File format information is given below, any sincer help is appreciated. Thnx.
        THE .MIX FILES
You probably already know the format of these files, but I will add a
description here for completeness.
The MIX file consists of two parts :
-A header including the index of all the files contained within
-A body containing all the files
It's format is :
 Header : record
            NumFiles : word;    {Number of files in MIX}
            DataSize : longint; {Size of body}
            Index    : array [1..NumFiles] of
              record
                ID    : longint;  {File ID}
                Start : longint;  {Offset of file from the start of the
body}
                Size  : longint;  {file size}
              end;
          end;
The ID field is computed from the original filename, which is not stored in
the MIX.
The records are always sorted by the ID field (the numbers are signed
longints).
Note that the offsets are relative to the start of the body so to find the
actual offset in the MIX you have to add the size of the header which is
NumFiles*12+6
All the above info written on MIX Files just goes over my head anyway
PostPosted: Thu Mar 10, 2011 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm also interested in this code Laughing.
I've tried several times to translate Olaf's XCC code to delphi, but I've failed.
Stealth Killer
PostPosted: Fri Mar 11, 2011 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh what a tragedy........
Let me know Banshee if you make it, i'm trying too.
PostPosted: Fri Mar 11, 2011 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Instead of translating hes code, what is buggy somewhat anyways, just learn the whole logic and format and write your own.
Stealth Killer
PostPosted: Fri Mar 11, 2011 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats what we are doing man. We cant find a proper information on those so called mix files, even westwood & EA sites does not contain any info on the files used by TS or RA2.
PostPosted: Fri Mar 11, 2011 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Westwood and EA sites would not. Perhaps sometime down the line i will produce one for the TS format (is there a difference between TS and RA2 formats?), we need a new mix exploring application >_>
EVA-251
Also Known As: evanb90
PostPosted: Fri Mar 11, 2011 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Among other things. Like a map editor. #Tongue
YR modder/artist, DOOM mapper, aka evanb90
Project Lead Developer, New-Star Strike (2014-)
Former Project Lead Developer Star Strike (2005-2012), Z-Mod (2006-2007), RA1.5 (2008-2013), The Cold War (2006-2007)
PostPosted: Fri Mar 11, 2011 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would be appreciated.
Anyway, I don't think that TS and RA2 mix files are different at all.
PostPosted: Sat Mar 12, 2011 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I got a ton of code for TS that trys to copy how the RA95 Editor works, very buggy, perhaps its work a beta release if i can get the mouse to work right.
ArvinCool
Tiberian Beast
PostPosted: Sat Mar 12, 2011 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Stealth Killer I hope this tool finish. Dont forget to make it able to open protected file.
"I'll be staying strapped cuse my mac-eleven make my nuts bigger"
PostPosted: Sat Mar 12, 2011 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Olaf's MIX code is totally cryptic and incomprehensible. Most of his code is, but that one's the worst by far. Unless you've studied maths maybe don't even attempt to make any sense of it. Your best chance is to directly translate C++ code to Delphi. Trying to understand it is a waste of time, you could easily write a new game in that time.
I attached the MIX loading code (C++) from a former... project of mine. It should be way more comprehensible than Olaf's work, however I left a huge part of Olaf's code untouched, for obvious reasons.
It could load TS and RA2 mixes, not sure about earlier versions, it's too long ago. I won't be able to give any support either. If there are any headers missing, I can offer them, though.
MIX.zip
 Filename:  MIX.zip
 Filesize:  12.64 KB
 Downloaded:  361 Time(s)
PostPosted: Sat Mar 12, 2011 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, pd Smile
I'll take a look at it, although I'll still need some help to convert the cryptic blowfish and the bignum stuff to Delphi, because that's the part I'm stuck with.
Stealth Killer
PostPosted: Sat Mar 12, 2011 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for this help PD. Now I have something to work on. And ArvinCool we will do our best to make it a smart one to read those protected ones too.
PostPosted: Sat Mar 12, 2011 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Forgot about Folkor pd, shame you stop working on that Sad
PostPosted: Sun Mar 13, 2011 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
"bignums" are nothing but arrays of unsigned integers. Have a look at the typedefs. Those functions are arithmetic operations.
There's a lot of pointer typecasting involved there, so in Delphi, where that isn't possible, you might be better off representing those bignums using unsigned byte arrays. That will be a lot of work for sure, but there's not much you can do really.
I can try translating a simple example, though my Delphi knowledge is extremely limited. If you know your way around bitshifting and arithmetic operations, you shouldn't have too much of a problem translating these monsters.
What they are for and why they are needed, I don't know. The whole decryption can most likely be achieved in easier ways, but as mentioned, research on that is probably wasted time.
Ivosh
PostPosted: Tue Jan 03, 2012 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Olaf van der Spek
PostPosted: Wed Jan 04, 2012 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got a link to your bug report?
Olaf van der Spek
PostPosted: Wed Jan 04, 2012 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
You should just move to C++ Wink
PostPosted: Thu Jan 05, 2012 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Thu Jan 05, 2012 8:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, pds diss to Olafs code is kinda hilarious Laughing Laughing Laughing
PostPosted: Thu Jan 05, 2012 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
pd, VK and various people who have studied the code have told me there is bugs in the save routines.
Olaf van der Spek
PostPosted: Fri Jan 06, 2012 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not going to get fixed if nobody posts a bug report...
ArvinCool
Tiberian Beast
PostPosted: Fri Jan 06, 2012 9:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
so where do we report bugs? Example, the String editor often crashes. Very annoying.
Olaf van der Spek
PostPosted: Sat Jan 07, 2012 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Mon Jan 09, 2012 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
@ArvinCool & few others: this is not how do you report a bug.
You have to:
- explain what happened (the bug you are reporting).
- what you were doing at the moment the bug happened.
- what have you done before the bug happened.
- describe your hardware, operational system, etc.
And post your bug reports at the links Olaf just posted above.
Sentences such as "String editor often crashes" means nothing for a software developper. We do not have crystall balls. The more you detail, the better.
Stealth Killer
PostPosted: Sat May 19, 2012 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Simple C Application to calculate Mix File ID http://freecnc.org/dev/mix-format/, I would request C++ professionals to give a similar code for TS and RA2 Mix files that just reads and writes mix files and adds or removes files from mix files ( it should be simpler, and by simpler I mean no external headers, units or something like that, they really blow my head as I'm new in cpp)
Any help Plzzzzzzzz ??????
[ Time: 0.1712s ][ Queries: 13 (0.0096s) ][ Debug on ]
