The time now is Fri Mar 29, 2024 1:05 am
[XCC] Unable to convert Aud Files...
Atomic_Noodles
PostPosted: Fri May 18, 2012 1:03 am    Post subject:  [XCC] Unable to convert Aud Files...
Subject description: Errors!!!
Before I used to have my XCC Mixer installed in Drive D (The Rar Version) Recently after moving all my CnC Tools to Drive C in a dedicated Folder I've been unable to convert Aud Files to Wav ever since. Whenever I try I always get a message on the bottom left corner saying "Error 1"
~ Excelsior ~
TiberFCSL
PostPosted: Fri May 18, 2012 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you reinstall XCC Utilities or just moved them?
Inactive Projects >> Tiberian Sun: Tech Level War http://www.ppmsite.com/forum/index.php?f=843
Download the latest beta: http://www.moddb.com/mods/cc-tiberian-sun-tech-level-war
Atomic_Noodles
PostPosted: Fri May 18, 2012 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Deleted it from Drive D, Installed XCC Utilities to its now new location, Drive C... since the start of February or so.
~ Excelsior ~
PostPosted: Fri May 18, 2012 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure you have the rights to write on the drive? (check if you're admin and if your XCC tools aren't in some stupid windaft system folder)
Where is the destination folder of the other XCC browser? This is the place where the file is going to, and if this is not set (due to the move), then it can't create the file there.
Post a screenshot of XCC Wink
Atomic_Noodles
PostPosted: Fri May 18, 2012 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Its set to the default location, "C:\Program Files\CnC_Tools\xcc_utilities"
Hmmm... I tried running XCC as Admin, I can convert aud files to WAV but I still have to do another step of using Extract.
However when I try to insert files I cannot do it while running in Admin Mode.
~ Excelsior ~
[ Time: 0.1460s ][ Queries: 11 (0.0078s) ][ Debug on ]
