The time now is Fri Mar 29, 2024 12:43 am
SHiFT [V0.05]
Post new topic   Reply to topic Page 1 of 1 [50 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Tue Dec 13, 2011 1:30 am    Post subject:  SHiFT [V0.05] Reply with quote  Mark this post and the followings unread
SHiFT
[V0.05] for TS V2.03
And so enters my second project that I have been working on. (somewhat)
This is the next patch I started after stopping development on Zeus, and releasing it to the community. It's called SHiFT and is better than the last patch I did in almost every single way. Better code, easier workflow, more features, and less prone to causing issues/bugs are just a few things off the top of my head. Naturally it's a DLL which is injected via Syringe. This is not a binary patch.
Since this patch is relatively new, there aren't too many things in it yet. But I'll go ahead and post the current features, nearly completed features, and planned features for future versions. Version 0.05 is the latest currently.
Completed Features:
;Rules.ini
;//New Section//;
[UI]
UI.InnerGlowDisable = Bool
UI.CurtainEffectDisable = Bool
UI.TextRemap01 = Hex #
UI.BorderRemap = Hex #
UI.MovementPathRemap = Hex #
UI.ToolTip.DrawBackground = Bool
UI.ToolTip.DrawOutline = Bool
UI.ToolTip.BackgroundColor = Hex #
UI.ToolTip.TextColor = [Color] Entry - (String)
UI.LoadScreen.TextRemap = [Color] Entry - (String)
UI.Sidebar.DisableDarkening = Bool
UI.Sidebar.AltDarkening = Bool
UI.Sidebar.AltDarkeningColor = Hex #
UI.Sidebar.OnHoldTextColor = [Color] Entry - (String)
UI.Sidebar.ReadyTextColor = [Color] Entry - (String)
UI.Sidebar.SuperWChargeColor = [Color] Entry - (String)
UI.Techno.DisableSelectBoxes = Bool
[General]
StartingCellScatter = Int
Debug.SoloMode = Bool
Debug.NullifyAttacks = Bool
[Building Type]
Building.AltIncome = Bool
Building.AltIncomeAmount = Int
Building.AltIncomeDelay = Int
Building.AltIncomeStartup = Int
Building.SpySat = Bool
[Unit Type]
Unit.EMPImmune = Bool
[Weapon Type]
Damage.Random = Bool
Damage.RandomMin = Int
Damage.RandomMax = Int
Weapon.Shake = Bool
Weapon.ShakeX = Int
Weapon.ShakeY = Int
Args
-NOLOGO
-NOCD
Partially Completed Features:
[General]
AircraftCostBonus = Float
InfantryCostBonus = Float
UnitCostBonus = Float
BuildingCostBonus = Float
[Building Type]
Building.IsIndustrialPlant = Bool
Building.IsSuper = Bool
Building.IsGarrisonable = Bool
Release:
         _      _ __
        /_`/_/./_`/
       ._// ///  /
                ----[V0.05]----
_______________________________
Created:     1/03/12
Released:    1/03/12
Version:     [V0.05]
TS Version:  [V2.03]
Created By:  Joshy
_________Description___________
Here is the first and last
stable, public release done by
me. Version 0.05 features some
decent additions to the TS
engine that I hope many will
find appealing. For a better
overview of the features in
V0.05 see the original topic
where I announced SHiFT to the
public.
This was created for testing
purposes and thus I take
no responsibility for any
issues that you encounter from
using this patch. I'm not
saying the patch is buggy, but
if you think you enounter a
bug from using the patch then
that's too bad. I won't be
around for bugfixes, coding,
or redistributing newer
builds. Also, partially
completed features I talked
about were NOT completed!
NOCD also has no function!
That being said, CCHyper will
be taking over SHiFT and all
the source code is in his
hands. He will be responsible
for any code additions or
newer versions of the patch.
Ultimately he does what he
wants with the code.
Have fun, enjoy the patch!
__________Schwing!_____________
--------------------[JP]-------
SHiFT_005.rar
[V0.05]
 Filename:  SHiFT_005.rar
 Filesize:  101.98 KB
 Downloaded:  341 Time(s)
Allen
PostPosted: Tue Dec 13, 2011 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no idea what most of that dose....
C&C in RA-1 Get it here
m7
PostPosted: Tue Dec 13, 2011 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool stuff Joshy. I'd love to see something to VideoBackBuffer= functionality in TS so I could actually play the game. Another cool feature would be the enhancements to the jumpjet locomotor that were in Red Alert 2.
PostPosted: Tue Dec 13, 2011 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh, cool to see you're announcing this, Joshy. Smile
Off the top of my head I can think of a few desired features...
Desired Features:
-Make LaserOuterColor work
-Allow passengers to fire from their vehicle
-Make Jumpjet infantry switch between flying and walking modes using the deploy command
-Tertiary Weapons
Some lovely features you've got there. If you need help testing them.... Wink
PostPosted: Tue Dec 13, 2011 3:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Ask on which one's you don't understand and I'll explain them.
Thanks. What's VideoBackBuffer do? Is this tag present in YR or something?
I may look into the locomotion, but that's tricky.
Desired Features:
-Tertiary Weapons
Thanks. Wink
1. Will check that and can probably get that done easily.
2. Also will check up on. Maybe look into something like an IFV too.
3. Unsure about this, may look at it.
4. *studies ETS*
Yeah, I'd be glad to have you testing it. (Esp. trying it on TO)
PostPosted: Tue Dec 13, 2011 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Tue Dec 13, 2011 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm looking forward for this. First desired features that come to mind would be
1. working air transport (lands all infantry at once)
2. Allow aircraft to use turrets/additional voxel sections
3. Allow aircraft to use secondary weapons
4. SHP aircraft?
5. Seperate survivor infantry type and engineer type (ConYard only) for the factions.
PostPosted: Tue Dec 13, 2011 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
BuildC--argmyheadmyheadmyhead?
PostPosted: Tue Dec 13, 2011 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
How about allowing unit types other than vehicles to carry infantry and/or possibly other unit types.
iamn00b
Jumpjet Infantry
PostPosted: Tue Dec 13, 2011 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
View user's profile Send private message Skype Account Yahoo Messenger Account
PostPosted: Tue Dec 13, 2011 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Joshy wrote:
Currently I'm lacking ideas for features to implement so feel free to post Bugs, Desired Features, Suggestions, Questions, or Whatever.
Hyperpatch Suggestions and Bugs pretty much sums it up already. Wink
But cool that you go in public with the project Joshy. Smile
Do you plan to make it compatible with Hypers binary hacks?
When can we expect the first test version?
iamn00b
Jumpjet Infantry
PostPosted: Tue Dec 13, 2011 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think this tag
Weapon.ShakeX =
Weapon.ShakeY =
is filled with int, not boolean.. or...
PostPosted: Tue Dec 13, 2011 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you can work out why the AI refuses to use even its own Construction Yard, even though I have removed the limit. then ill release it.
PostPosted: Tue Dec 13, 2011 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where does the AI stop working?
Does it refuse to deploy its separate mcv? Do you changed BaseUnit as well?
Or does it refuse to build any building, once it has the separate conyard deployed?
PostPosted: Tue Dec 13, 2011 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
BaseUnit seems to work fine, BuildConst, well, no matter what, any AI house fails the check.
PostPosted: Tue Dec 13, 2011 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
The check fails on the second building in the BuildConst list or then on every building?
Isn't BuildConst also used for some player settings, so you can check if it's actually used correct?
e.g. wasn't the powerplant, since it has no prerequisite, checking for the building under buildconst? So as a player you could check if you have the correct powerplant or the greyed out buildoptions bug.
The AI might refuse to build due to a different problem and via a player check, you could narrow down the problem.
PostPosted: Tue Dec 13, 2011 11:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
4. SHP aircraft?
1. I haven't researched at all so it will be new to me.
2, 3, 4: Also new, I haven't done anything with aircraft so I'll have to study it.
5. Could very well do, I'll look into that!
Nah, no thanks. Razz
Hm, kinda like how the hovercraft in YR can take vehicles? Could look into it, also reminds me of things being able to deploy into any type. IE - like the GI in YR.
Yeah, I often go there when thinking of features, or to the old ETS topics and wishlist. Still, fresh input and ideas are more than welcome and people can always think of something new.
Thanks Wink
Hm, not sure. My hook points would overwrite his on launch so it could cause issues with similar logics between the patches. As for a test version, probably soon since I've been the only one testing it and suck at it. #Tongue
iamn00b wrote:
i think this tag
Weapon.ShakeX =
Weapon.ShakeY =
Nice catch, I fixed the first post. They are supposed to be integers.
A feature I'd like to explain some more right now is my sidebar darkening features:
First off I allow the user to skip the entire loading/drawing sequence of darken.shp with UI.Sidebar.DisableDarkening. Which is nice and doesn't require any messing with that shp. Then I took it a step further and offered an alternative type of darkening that is faster than drawing darken.shp.
Pictured above:
UI.Sidebar.DisableDarkening=true
UI.Sidebar.AltDarkening=true
UI.Sidebar.AltDarkeningColor=E3FF49
Basically it draws filled black rects to mask the things that are not currently being built. It is not transparent but you don't suffer from any lag at all. Additionally you can specify UI.Sidebar.AltDarkeningColor and the game will draw a small outline on the thing currently in production to make it pop more. (It's a small gold outline in the picture)
You may also notice the drop pods "Ready" text:
UI.Sidebar.SuperWChargeColor=Red
And here's a few more of the UI features:
UI.MovementPathRemap=49FF9A
UI.Techno.DisableSelectBoxes=true
UI.ToolTip.TextColor=Purple
UI.ToolTip.DrawBackground=true
UI.ToolTip.DrawOutline=false
UI.ToolTip.BackgroundColor=0
UI.ToolTip.BackgroundColor=FFFFFF
UI.InnerGlowDisable=true
UI.CurtainEffectDisable=true
UI.TextRemap01=FFFF
UI.BorderRemap=FFFF
FurryQueen
PostPosted: Wed Dec 14, 2011 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Sweet Jesus man. You're making me almost want to mod Tiberian Sun.
KGR | AT
AZUR
Discord: theastronomer1836
Steam
iamn00b
Jumpjet Infantry
PostPosted: Wed Dec 14, 2011 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
moar ask :
what this? what i first is make units scatter from mcv at game start, allowing deploy mcv without moving it. But i see it use to be fill with int, and then i have no idea
and also:
[General]
[Building Type]
this is for?
PostPosted: Wed Dec 14, 2011 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
@Yoshi: If you and Hyper cooperate with each other, wouldn't you be able to make sure your patches remain compatible with one another? That way we won't end up with 2 different patches with similar features (so you then won't both have to do the same work) or having 2 patches with completely different features, but forcing modders to chose between the patches since they aren't compatible (meaning a single mod then won't be able to have the features from both patches).
So in the end making sure SHiFT and HyperPatch remain compatible will be more convenient for everyone I imagine.
View user's profile Send private message Send e-mail ModDB Profile ID YouTube User URL Facebook Profile URL
Krow
PostPosted: Wed Dec 14, 2011 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
What Bittah said. Very Happy
Team Black wrote:
PostPosted: Wed Dec 14, 2011 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
But if binary hacks change the locations of things, wouldn't that make the .dll patch not work? Unless the patch was built to work with the altered offsets, which would break it with the regular game?
Allen
PostPosted: Wed Dec 14, 2011 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Since your asking for a wishlist. I want RA1.
Working air transport for infantry. Busted with the Firestorm patch
Working ShipYard and ShipType.
Ship Tranport that can load vehicles and men. I guss it would have to be like the RA2 hovercraft
RA2 style spread= for rules so we can make good nuke. The Art.ini crap to make a nuke is buggy if you ask me
Clone of all TS super weapon logics
Airstike/parbomb super weapon
Paradrop super weapon
Chrono Tank logic
Chronosphere super weapon
PostPosted: Wed Dec 14, 2011 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I'll be leaving soon, and come that time Hyper will take all my code.
Volgin
PostPosted: Wed Dec 14, 2011 6:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can I take your hymen?
Victory!
SMIFFGIG
PostPosted: Wed Dec 14, 2011 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting you should do this as I remember seeing in a really late beta build screenshot of TS, the SW charge text was a skyblue colour
DDragon
PostPosted: Thu Dec 15, 2011 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
So i have this clear Joshy, is this stuff like the different colour borders and buttons customizable by the end user or is it a 'hard coded' thing within the patch?
Darkness Consumes those that fall behind - DD
View user's profile Send private message Send e-mail Skype Account Yahoo Messenger Account AIM Address
PostPosted: Thu Dec 15, 2011 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
of course customizable by the modder, else he wouldn't have shown the long list of new rules.ini keys in the first post.
DDragon
PostPosted: Thu Dec 15, 2011 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
just making sure i was following it right thats all lol
PostPosted: Thu Dec 15, 2011 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
iamn00b wrote:
moar ask :
and also:
[General]
[Building Type]
this is for?
StartingCellScatter, is what you thought. It's based on an integer because the higher the number the further away the units are from the center point, which is the mcv. Basically how YR games start out and you don't have to move the mcv.
The bonus tags are for the Industrial Plant logic, I took those keys from YR. They are for the percentage to take off the cost of each type when buying.
IsSuper is for the checkbox I'll add to the skirmish menu: (x) Superweapons
As you can guess it will mark all the superweapon buildings and they won't be buildable ingame if the checkbox is marked.
@Smiff: aye that is a working tag
@DDragon: You are right, these things are modifiable by the end user in the ini files.
And sorry I can't get all the responses, I'm posting on my phone right now.
PostPosted: Thu Dec 15, 2011 6:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please make directly only the SuperWeaponTypes unavailable, because many SuperWeapon Buildings are still used as prerequisite for other things.
So your current solution is nothing different than giving only SuperWeapon Buildings Techlevel 10 and all other buildings techlevel 9 and below, so you can disable them via the techlevel slider.
Regulus
PostPosted: Thu Dec 15, 2011 7:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would like to see sidexx.mix accept more things like pips.shp and what not. That would be nice. Rubble like in RA2 would be really nice too, but none of these are really game changing.
You come for the modding but you stay for the Crap Forum.
PostPosted: Tue Jan 03, 2012 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, released. Cya!
PostPosted: Tue Jan 03, 2012 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Call me dumb but what's with the dot in almost every key?
^ I'm talking about this.
PostPosted: Tue Jan 03, 2012 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its a formatting style.
In HP i use Infantry.Example= and Unit.Example= that way keys don't get mixed up and you know what type of object they belong to.
PostPosted: Tue Jan 03, 2012 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wooo! SHiFT! Very Happy
Holy_Master
PostPosted: Wed Jan 11, 2012 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
any chance for 3rd faction or seperate MCV?
OrangeNero
PostPosted: Wed Jan 11, 2012 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
This is very interesting. I read about an oil derick feature like in RA2? how would this be done?
Additions I could think of is a prism weapon and shootable missiles like V3 and a starting position selection.
In any case SHiFT is much appreciated.
Free Tibed!
OrangeNero
PostPosted: Fri Jan 13, 2012 12:13 am    Post subject: Reply with quote  Mark this post and the followings unread
In all your glory on what you achieved you forgot to write anything useful into your readme. I guess I have to just put these files into the TS directory and then guess it will work?
Its nice to see:
[Building Type]
And read in the newspowst that this patch includes oil dericks but what am I supposed to do with this?^^
Free Tibed!
PostPosted: Fri Jan 13, 2012 12:25 am    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't include oil derricks, but you can use the tags you've just mentioned in your last post to create a building that behaves like an oil derrick.
PostPosted: Fri Jan 13, 2012 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Run the RUN.bat and any SHiFT related changes you've made to the inis ought to work.
Palkia323
PostPosted: Sun Jan 15, 2012 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
When I run RUN.bat I get an error stating "This product requires a 16bit pixel depth!"
How can I solve this?
Tore wrote:
Oh noes Nod32 must have found some GDI32 in the art.ini file!
3ds Topic
Clicky
Allen
PostPosted: Sun Jan 15, 2012 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a feeling that SHIFT wasn't made with Win 7 in mind. Win7 will no longer use 16bit programs.
PostPosted: Sun Jan 15, 2012 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
This can be solved by simply undoing the windowed mode command line. (You also might want to put the new "-NOCD" and "-NOLOGO" lines in there.)
You can do this by:
- Right Clicking on the Run.bat
- Deleting "-WIN" at the End
- Saving then Running Run.bat
Problem Solved. Very Happy
Anyhow, nice patch, it looks like I'll have to redo my menu cursor...
Allen
PostPosted: Sun Jan 15, 2012 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
You can do this by:
Don't use Win 7 for C&C still using XP. Don't have to deal with that BS but is helpful to Palkia323
PostPosted: Sun Jan 15, 2012 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
The color depth doesn't have anything to do with the program's architechture. Even 64-bit programs can run on 16-bit colors, and TS is 32-bit like almost everything from that time.
TS just requires 16-bit colors (it will set them automatically when run fullscreen), and will throw that message if the user is using a different color depth and tries to run TS in windowed mode.
Tartan Bunny
Flamethrower
PostPosted: Sun Jan 15, 2012 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I've noticed a few bugs with shift.
More than one team in multiplayer can use the same colour
Fire anims and explosion don't show.
SpySat applies to all players
Random Map generator gets stuck, have to force end the program
PostPosted: Sun Jan 15, 2012 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also doesn't work with custom EXE's like it's supposed to, at least, it doesn't work with TI's EXE.
pd
PostPosted: Thu Jan 19, 2012 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good luck with this one!
As long as no code addresses are affected by the custom exe, it should. I cannot remember how the exe is laid out and how exactly Syringe maps hook addresses (whether it's file addresses or virtual addresses, has been a long time really), but if you load custom icons or string tables in there and the resource segment comes before the code segment, stuff will get screwed and there's nothing you can do except providing separate injection information files.
SMIFFGIG
PostPosted: Fri Sep 21, 2012 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I think i remember Joshy saying he's not working on this any more
But those that you mention do seem like some pretty major bugs!
[ Time: 0.2767s ][ Queries: 13 (0.0106s) ][ Debug on ]
