The time now is Fri Apr 19, 2024 11:01 pm
Adding sounds to your Tiberian Sun Mod
Post new topic   Reply to topic Page 1 of 1 [13 Posts] Mark the topic unread ::  View previous topic :: View next topic
The DvD
TiberiumWeb.com Webmaster
PostPosted: Sat Feb 21, 2004 9:21 pm    Post subject:  Adding sounds to your Tiberian Sun Mod Reply with quote  Mark this post and the followings unread
This tutorial will teach you how to make, add, and apply sounds to your TS mod.
Sounds for Tiberian Sun are in .aud format. It's a compression format like Mp3, only a bit worse in quality. Note that both songs and sfx are in .aud format.
1) To create .aud files. .aud can be created using a plugin for the widely know WinAmp (www.winamp.com) media player. I believe it's included with XCC Utilities (http://xccu.sourceforge.net/). After you've applied the plugin, you can select it as the way WinAmp outputs the media. Play your files as you normally would but with Aud Writer enabled as output format.
NOTE: if you're using WAV files, make sure they're in 16 bit stereo 42.something KiloHertz. Fiddle around with this if it doesn't work.
2).aud files should be addes to ecache MIXes. See the Tutorial Creating and Managing your MIX files for more info.
3) If your new .aud is a song, open theme.ini or theme01.ini if you're using Firestorm. Add the filename, without extension, to the list. Also make a correct entry like how is done with the existing songs.
If your new .aud is a sound effect, open sounds.ini or sounds01.ini. Again, you need to add the filename to the list (with a lower number than BOOP)
and you may also create an entry, if you require the additional options. These options are priority (default=10, max=100) and Volume (default=1.0)
4) For a sound effect, there are several ways to make in appear in the game. It can be added to an animation in Art.ini, or a weapon in rules.ini by adding the line Report=yournewsound. It can be added to a unit's voice by adding it to the entries like VoiceSelect, VoiceReporting etc (note this also works for buildings). You can also add this sound to one of the sound events that are specified in the AudioVisual section near the top of rules.ini.
Key Words: #Tutorials #Modding #TiberianSun #Firestorm #Rules.INI #Sounds.INI #WinAmp #XCCAUDWriter #XCCUtilities
christophski the great
PostPosted: Tue Jun 15, 2004 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I followed the tutorial Dvd but i can't get my song to work
heres the code
23=WAKEUP
[WAKEUP]
Name=WAKE UP
Length=6.03
Scenario=1
Singer-Songwriter Christie Isaac
GeckoYamori
PostPosted: Tue Jun 15, 2004 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you put it in the right .mix? Are the sound settings correct? Tiberian Sun's default .aud music is 22050khz 16-bit mono.
PostPosted: Tue Jun 15, 2004 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
how the hell do you do that to a .wav
iceman559
PostPosted: Tue Jun 15, 2004 5:19 pm    Post subject: Re: Adding sounds to your Tiberian Sun Mod Reply with quote  Mark this post and the followings unread
This is how:
NOTE: if you're using WAV files, make sure they're in 16 bit stereo 42.omething KiloHertz. Fiddle around with this if it doesn't work.
<b>::Counter-Strike File Source</b>
<b>::The Army of Chaos Empire</b>
View user's profile Send private message Send e-mail Visit poster's website Skype Account AIM Address
Ackron
PostPosted: Tue Jun 15, 2004 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
iceman? iceman lives? i thought he was dead!
must have been your first post for ages iceman
Fremen5
Location: Laughing at Donald Trump in a rather flat place
PostPosted: Tue Jun 15, 2004 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, ackron.
He posted a few days ago, if not yesterday.
Tiberian Station
Image guy on the Dune Sun\
- Peace - Through - Wossname -
Ackron
PostPosted: Tue Jun 15, 2004 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
duhh stupid me #Tongue
WingDingo
PostPosted: Fri Sep 30, 2005 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Uh, what do you do when it's the map selection song that's already ingame, but you already copy pasted it and renamed the new song?  Here's what I got...
[MAPS]
Name=Map Selection
Repeat=yes
Normal=no
[DDAY]
Name=DDay
Length=2.41
Scenario=1
Side=GDI
DDAY is what I renamed it too.
The DvD
PostPosted: Sat Oct 01, 2005 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Already answered that.
Alexander C Bukington
PostPosted: Sun Jul 22, 2007 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
how come I dont have a "theme.ini" in my tiberian sun directory? I have TFD BTw if that helps.
PostPosted: Sun Jul 22, 2007 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
you have to extract it from expand01,mix or tibsun.mix depending on which version you want to use
PostPosted: Tue Jul 24, 2007 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i found and extracted theme.ini and I edited it. Now XCC wont let me integrate my new theme.ini into the .mix files!!! Also XXC for some reason is only noticing that I have RA2 and not TS yet I can gain access to all the TS files...
[ Time: 0.1532s ][ Queries: 11 (0.0081s) ][ Debug on ]
