The time now is Thu Apr 25, 2024 3:47 pm
Hva editor cant use custom palettes
Kcirevam
PostPosted: Fri Aug 05, 2011 1:40 pm    Post subject:  Hva editor cant use custom palettes Reply with quote  Mark this post and the followings unread
As mentioned above, HVA editor only uses unittem.pal , maybe the TS one too, I can't change the palette to my custom one unless I override unittem.pal, which I don't want to keep doing all the time when I want to use the normal palette.
This is a minor issue but I don't like to be working on something I can't understand what it is.
Also known as superluigi949 and SuperMario949.
Banned for pretending to be someone else.
PostPosted: Wed Aug 10, 2011 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Voxels can't use custom palette, neither in Ares nor in NPatch, so I don't see where the issue lies.
PostPosted: Fri Aug 12, 2011 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Correct, admittedly if an Building is given custom palette and it has voxel turret then the voxel turret will endup using that particular palette BUT BUT, it still uses the VPL indexes that normally point to unittem.pal etc indexes depending on theater and since vpl is designed for unittem.pal indexes, it may endup awfully wrong looking unless really design another palette very similar to unittem.pal but in wanted shades.
Else a separate totally custom palettes for voxels is just not an option as this would demand also custom VPLs linkup to them and this is not possible.
So whatever you are trying to do...??? having the no custom pal support in hva editor is the least of your problems.
[ Time: 0.1577s ][ Queries: 11 (0.0086s) ][ Debug on ]
