The time now is Thu Apr 25, 2024 8:11 pm
VQA Encoder v0.5 beta 2
Post new topic   Reply to topic Page 3 of 3 [138 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: Previous 1, 2, 3
wunder
PostPosted: Tue Aug 26, 2008 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. it's me again this time registred.
After i load gdi.avi file, menu looks like this:
http://www.wrzuta.pl/obraz/81zNeTgaSV/bez_tytulu
I can't change anything, just keys and blocks. Nothing more nothing less...
How to click on this 8-bit option?
PostPosted: Wed Aug 27, 2008 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can't convert AVI to 8-bit VQA, beause AVI format is pretty much always high-colour. You need PCX frames.
wunder
PostPosted: Wed Aug 27, 2008 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Omg, when i convert from avi to pcx i have 154 files!!! In VQA Enc i can use ONLY 1. So what with rest? Or how to convert whole this files to 1 vqa file?
Sry for so many questions but im not so smart for this.
MrFlibble
PostPosted: Fri Aug 29, 2008 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not "only 1", you need put the name of the first file, given that your files are named like "file 0000.pcx", "file 0001.pcx" etc., the encoder will recognize this pattern automatically.
I am MrFlibble. Just MrFlibble. From the Potato King to Uncle Arnie to MrFlibble. I am his right hand.
FED2k Forums - Westwood Studios' Dune games and more
PostPosted: Fri Feb 11, 2011 8:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoo-hoo, it works!
Thank you ugordan. Smile
Oh, and *bump*.
Sincerely,
Brandon
Brandon
PostPosted: Tue Feb 15, 2011 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
What program is everyone here using to convert their .AVI file into PCX files?
I used RAD Tools for the C&C95 .avi videos I extracted, but I can't get RAD Tools to convert the TS .avi videos (Note: For the TS avi > pcx conversion through RADTools, I have the 256 color option unchecked). I get the error "Unsupported output file type or color depth".
BTW, ugordan, your program is the only one I have seen anywhere that enables tinkering with the C&C series videos. Thanks again. Very Happy
Sincerely,
Brandon
If anyone is curious as to my methods and goal, here it is:
STEP I - Extract AVI:
In this example, I am trying to modify the GDI intro video. I load the MOVIES01.MIX and extract file C432F319 as an AVI. Play and check its codec info in VLC media player:
Steam 0
Type: Video
Codec: 24 bits RGB (RV24)
Resolution: 640x400
Display Resolution: 640x400
Frame rate: 15
Steam 1
Type: Audio
Codec: PCM S16 LE(araw)
Channels: Stereo
Sample rate: 22050 Hz
Bits per Sample: 16
File size: 1.95GB
Length: 3:01
STEP II - Edit AVI:
I then use some free video editor I can find online -in this case "Video Pad"- and edit the AVI. I then save the new AVI and check its codec info in VLC media player:
Steam 0
Type: Video
Codec: Indeo Video v5 (IV50)
Resolution: 640x400
Frame rate: 14.999992
Steam 1
Type: Audio
Channels: Stereo
Bits per Sample: 16
File size: 57.9MB
Length: 2:56
STEP III - Extract sound:
I then open up VLC media player, go to File>Convert/Save.... I then convert the new AVI file to a WAV file and check its codec info:
Steam 0
Type: Audio
Channels: Stereo
Bits per Sample: 16
So now I have two files to work with:
mod_C432F319.avi
mod_C432F319.wav
STEP IV - RAD Tools:
For the C&C95 movies, I converted the AVI with the 256 option checked and it converted the frames into PCX files easily. But for TS I get an error.
STEP V - VQA Encoder:
If I can get the PCX files I'll be able to move to this step. It would look something like this:
Input File: ...\Desktop\temp_vidwork\mod_C432F31900.PCX
Sound File: ...\Desktop\temp_vidwork\mod_C432F319.wav
Output File: ...\Desktop\temp_vidwork\mod_C432F319.vqa
VQA type:
15-bit VQA (HiColor)
Movie parameters:
Resolution: 640x400(4x4)
Frame count: 2641 frames
Frame rate: 15 fps
Sound: 22050 Hz, stereo
Number of blocks: 6000
Key interval (frames): 64
Brandon
PostPosted: Wed Feb 16, 2011 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
**UPDATE**
Well, using RAD Tools, I converted the AVI frames into BMP instead of PCX.
Worked like a charm. Smile
However the movie looks "blockier" in-game than the original did. Perhaps I can up the number of blocks with the Ugordon VQA Encoder?
PostPosted: Wed Feb 16, 2011 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
VQA is a lossy format. Reconverting original videos inevitably leads to a decrease in quality.
Also, you saved your in-between result with a codec. That's also quality loss; better save it as raw avi when editing.
I don't think changing the default settings is a good idea though.
Brandon
PostPosted: Wed Feb 16, 2011 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah. I don't know if the video editor I am using at the moment allows for that. Confused Know of good video editing software that isn't "adobe-style" priced($500-$5000)? The last video editor I remember using that was any good was Premier, and that was back in high-school over a decade ago. I use GIMP and Audacity for graphics and sound.
In the VQA Encoder? Agreed. I notice Ugrodon above mentioned that 2000 blocks was a bit low for a TS movie so I wondered what upping the values -and to what point- would do.
Thank you for the response Nyerguds.
-Brandon
PostPosted: Wed Feb 16, 2011 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's usually just a matter of changing the codec to 'RGB'.
As for programs... well, it all depends on what kind of video editing you want to do. But most paid packs nowadays have open source alternatives.
PostPosted: Wed Feb 16, 2011 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Virtual Dub might be of help to you, but its quite advanced.
Brandon
PostPosted: Wed Feb 16, 2011 11:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tinkering with it now. Looks really promising. I can even export as an image sequence much faster and easier than in RADTools, and in any file type I desire (currently using BMP format with .pcx extension, although there are a few to choose from -tga, etc.). Any reason why I shouldn't use this program instead of RADTools? Confused
Thanks CCHyper. Smile
Hahaha. There is something very nostalgic and fun about being able to modify an old game like this that I played back in "the day". Were I still in middle-school this would be a dream come true. Razz Maybe just for kicks I'll throw a 2lt Coca-Cola bottle picture on a single frame in one of the movies. lol.
Thanks again guys. Cool
Brandon
PostPosted: Wed Feb 23, 2011 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
What exactly is the relation with the "Number of blocks"/"Key interval (frames)" properties?
I'm experimenting, trying to find the best input here.
C&CDOS/RADOS...
[Not tried]
C&C95/RA95...
[Not tried]
TS...
Currently using this:
Number of blocks: 32000
-Brandon
PostPosted: Wed Feb 23, 2011 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's no difference between DOS and Win95 C&C1 and RA1. It's all the same VQA format.
Brandon
PostPosted: Wed Feb 23, 2011 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ugordon mentioned on page 1 of this Thread about using different block numbers on different resolutions for C&C.
-Brandon
Brandon
PostPosted: Tue Mar 15, 2011 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE - 3/14/11
Well, I have managed to encode TS and RA1 movies with great success. I am now trying to do the same with the C&C95 movies.
They play fine in the XCC AV Player, but for some reason, they are looking corrupted when played ingame. Confused
I used RAD Tools in 256 color mode to make the PCX frame files, 256 color mode in the VQA Encoder.
PostPosted: Wed Mar 16, 2011 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, for C&C95 you have to make sure
  • all frames in one scene have the same palette. Palette switches can only happen at key frames (normally set to 8), so make sure scene switches obey this rule (only switch at multiples of 8) or you get some messed-up frames in between.
  • the maximum size is 320x200
  • the first colour is black, especially for videos smaller than the full 320x200 (like, for example, the game's original 320x156 briefing vids) because colour #0 is used to fill the space around the video. You can force this in RAD by reducing to 255 colours and starting from the second palette colour.
I use these settings in RAD tools:
Brandon
PostPosted: Wed Mar 16, 2011 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alllright Nyerguds, you brought me into the forums. Smile
Here we go...
* all frames in one scene have the same palette. Palette switches can only happen at key frames (normally set to 8 ), so make sure scene switches obey this rule (only switch at multiples of 8 ) or you get some messed-up frames in between.
What do you mean by "scenes"? What are they exactly, and how do I create them or know when/if they are being created?
Here's my current situation:
1.) Let's say I am modifying the first of the C&C95 NOD briefing movies (and I am. lol). I get the extracted AVI file through the XCC Mixer...
nod1.avi
320x156pxls
15fps
6205kbps
8bit
Uncompressed
2.) I then go into VirtualDub and remove a few frames I don't want and maybe add a fade/transition. Whatever I like. I am left with the following...
nod1.avi
320x156pxls
15fps
17904kbps
24bit
Uncompressed
3.) Now I have to get the modified movie converted into frames of some kind. VirtualDub and RAD Tools can both do this. VurtualDub has no option for PCX so I would normally use the BMP option, however I think this crashed C&C95 when I tried it so I decided to use RAD Tools exporting as PCX. In this case, I am using your setting you just posted above. I am now left with 316 PCX files ready for encoding.
4.) Encoding done! Now I have the following two files...
nod1.vqa
2.87MB
nod1.vqp
32.1KB
5.) I create a SC-00x.MIX file (SC-005 in this case) with the XCC MIX Editor, make sure it is in TD mode, then add the two files. Place the new MIX file in my C&C95 directory.
The end result... (Sorry for the way this looks. The PrtScn key decided it wasn't going to work for taking screenshots of C&C95 so I used my camera)
 Filesize:  155.26 KB
 Viewed:  21553 Time(s)
PostPosted: Wed Mar 16, 2011 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
What I mean is, usually the whole video is in the same palette, but if your video is comprised of 2 parts with vastly different colours, you can keep better colour quality by converting them separately so all frames of the first part have the same palette, and all frames of the second part have the same palette. But if the key frames are set to 8 (the default for 8-bit in vqa encoder) the game can only switch to diffferent colour palettes at every 8-frame mark.
Videos don't need to be in a mix file to work, and the format of addon mixfiles isn't "sc-###.mix". Any mixfile starting with "sc" will be read. "scorpion.mix" would work perfectly. But as I said, not needed for videos.
If you use cnc-ddraw you can use ctrl+s for print screen. That might be more clear than what you got there.
[edit]
I just realized what your problem is. You forgot to add the .vqp files to the game folder. The game uses those to calculate the in-between colours when stretching the videos #Tongue
PostPosted: Fri Mar 18, 2011 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Understand it now. Thanks.
Alright. I guess I am thinking in the same way as making a TS mod as explained here: http://www.ppmsite.com/forum/viewtopic.php?t=20064 ("expandXX.mix or ecacheXX.mix files"), where the order of the MIX files makes a difference.
It would be nice to have any mod files for C&C95 in one convenient file. Is there a way to do that, or do the video files HAVE TO be placed directly in the C&C95 folder?
Placing the VQA and the VQP in the main folder -and using your RAD Tools trick- did it. It works now. Razz
Thanks again. Smile
PostPosted: Sat Mar 19, 2011 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I didn't say it didn't work in mixfiles, I just said it's not needed. You can use the "SC*.MIX" format, as I explained it there, and for adding/overriding graphics or sounds it's usually needed anyway.
Videos (and music tracks) don't need it, but that doesn't mean you can't put them in there anyway.
Brandon
PostPosted: Sun Mar 20, 2011 1:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to put the vid files (both the VQA and VQP) in a MIX, but when I do that it ends up corrupted in-game. Placing the VQA and VQP directly into the main game folder works, but is undesired.
PostPosted: Sun Mar 20, 2011 8:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, that's because the sc*.mix files don't have priority over update.mix (which contains the .vqp files for all videos) in the original game.
Update to v1.06 (see my signature) and that should be fixed.
Brandon
PostPosted: Sun Mar 20, 2011 9:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
I sense I do not fully understand the directory/MIX file hierarchy or structure of C&C95. Laughing
Thanks Nyerguds. I'll experiment.
PostPosted: Wed Mar 23, 2011 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, sc*.mix files are supposed to be addon files, but in C&C the rule is simply that anything that's loaded first is given priority.
And in C&C95, the update.mix (all movies' VQP files) and updatec.mix (all UI graphics) were loaded before the sc*.mix files.
This was obviously retarded since it severely restricts modding and adding stuff, so my patch fixes it. Click on my signature to download it.
Evengard
PostPosted: Fri Mar 13, 2015 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
The source code wasn't released?
PostPosted: Fri Mar 13, 2015 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Doesn't appear so and ugordan appears to have vanished.
Exley
PostPosted: Fri Mar 13, 2015 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
you could trace him down, just google for name
Gordan Ugarković
hes doing some astronomical thingies #Tongue
how did we end up here ?
this place is horrible ...
smells like balls ...
PostPosted: Fri Mar 13, 2015 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finding info on what he's been up to isn't difficult, finding a current e-mail address seems to be though.
Exley
PostPosted: Sat Mar 14, 2015 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i could probably find him
he lived like ~70 km away from me #Tongue
i just don't want to kill his privacy with whole search and backtrack of his whereabouts
PostPosted: Mon Mar 16, 2015 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Lets not go all stalker on the poor guy, would just be nice if he could release the source for the encoder if he isn't wanting to maintain it anymore.
PostPosted: Sun Jun 11, 2017 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like the download in the first post is broken.
Anyone still have the latest version of the VQA Encoder?
Plokite_Wolf
PostPosted: Sun Jun 11, 2017 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Administrator of CNCNZ.com and EVA Database, the C&C Wiki
PostPosted: Sun Jun 11, 2017 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
The old downloads (pre-2015) will be fixed soon. Sorry for any inconvenience.
roscado
PostPosted: Tue Jul 02, 2019 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi,
  Sorry for reliving such an old thread, we want to translate the nox game videos that use the same format or similar to red alert.
To subtitle the videos we need to extract the video in images add the subtitles to the images and then reinsert them creating a VQA. Extracting the video in images and reinserting them works correctly but when the audio is added, the image of the video is distorted completely, I have tried infinite combinations with different numbers of block and key interval with the same result.
  I attach the results, I would appreciate if someone could help us or tell me how to contact the creator of the tool.
  https://mega.nz/#!cd5QXASQ!HyxApd6mlwYoR9Phk7sxhFEomI2hfoqj-WDcSC1A3jg
Greetings and thanks for your time.
PostPosted: Wed Jul 03, 2019 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like an issue with muxing the audio if just doing the video on its own works okay. The VQA format itself varies subtley between games, so its possible its one of these subtle variations that is tripping you up though as the tool is only intended to work for C&C and TS style videos.
I actually succeeded in obtaining the source, but ugordan was unhappy with his code quality and asked that i not release it which I intended to respect. My intention was to use it as a reference to either create a new implementation or to add support to something like ffmpeg. Its on the large list of projects I'd like to do, but I'm focusing on recreating the Red Alert and SAGE game engines currently. If we determine that it needs tweaks for NOX however I could look at building a new version of it.
roscado
PostPosted: Sat Jul 06, 2019 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
HI,
  Thanks for your comment blade, I'm still trying combinations, but it's like looking for a needle in a haystack.
Greatings.
FekLeyrTarg
PostPosted: Sat Nov 09, 2019 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
My apologies for reviving the thread once again.
I'm attempting to convert a 84 frames long BMP-sequence to a VQA-file made for TS.
The resolution is 640x400 and the frame rate is set to 15 FPS.
I've also provided a 22050hz WAV-file.
Colors are set to HiColor, number or blocks is 4000 and key interval is 64.
Any time I start the conversion process, I receive the "Buffer overrun detected!" message.
Do you guys have any idea what I'm doing wrong?
I'm using Windows 10 and my GPU is an nVidia Geforce GTX 950M.
I've provided a frame from that sequence so you can have a look.
(A little side-question by the way: Has there ever been a successor to the VQA Encoder?)
EDIT:
I found the solution to my VQA problem!
After exporting the video from Premiere Pro as BMP-sequence, I used VirtualDub to save that sequence as uncompressed AVI.
The VQA Encoding ran perfectly.
Important note:
Do not export as uncompressed AVI from Premiere Pro directly, as Adobe's Media Encoder does some encoding, which confuses the VQA Encoder somehow.
As a thank you gift for your help, I'm providing you with the VQA-file. :smiley:
test_3_cycles_0001_4by300.rar
The VQA-file
 Filename:  test_3_cycles_0001_4by300.rar
 Filesize:  2.41 MB
 Downloaded:  47 Time(s)
test_3_cycles_0001_4by349.rar
The frame I originally provided
 Filename:  test_3_cycles_0001_4by349.rar
 Filesize:  547.91 KB
 Downloaded:  7 Time(s)
Post new topic   Reply to topic Page 3 of 3 [138 Posts] Goto page: Previous 1, 2, 3
[ Time: 0.2646s ][ Queries: 14 (0.0149s) ][ Debug on ]
