The time now is Thu Mar 28, 2024 10:28 am
Open Source SHP Viewer(build 0.965)
Katz
PostPosted: Sun Sep 26, 2010 11:49 am    Post subject:  Open Source SHP Viewer(build 0.965) Reply with quote  Mark this post and the followings unread
UPDATE: Version 0.965
I was to write a little tool for viewing SHP(TS/RA2) and SHP(TD/RA) files.
This tool can preview your sprite in the way it will look in-game, with applying TS/RA2 shadows, turrets with offsets and custom color remaps.
The tool was made for Sandbox and OpenRA projects, and now it goes to public.
It is open source under GPLv3. C# Sources can be downloaded at my GIT: http://github.com/katzsmile/OpenRA
The tool is based on SHP(TS) format parser by Banshee, Olaf van der Spek & Stucuk, remap code and SHP(TD/RA) format parser by OpenRA team.
GIF engine by gOODiDEA.NET
Also big thanks to DerDmitry(aka Morpheuz) for his help.
WARNING: This program requires NET framework 3.5 Sp1!
Changes:
build 0.965
+ Reading APNG
* Refractored SHP(TS) reader code. Work much faster
* Redone rendering engine. Now this Render-On-Demand instead of render all frames to array
* Redone Shadow and Turret code. Work faster and turret rotation is now separate from body rotation
build 0.962
+ Store settings in prefs.yaml
+ Support BMP, GIF and JPEG as backgrounds
+ New Desert and Snow background images
+ Palettes is now sorted by folder
* Fixed bug with single frame rendering
build 0.96
- Removed frames panel due lags(and was not been very useful)
* When choosing any options frame position no more dropped to 1
* Fixed bug with SHP(TS) frame size
* Fixed bug with SHP(TS) frame image offset
build 0.953
* Fixed bug with SHP(TS) frame count
* Fixed bug with form resize
build 0.95
+ Export viewport as animated GIF
* Replaced GIF engine with new by gOODiDEA.NET
* Trying to fix bug with turret frames count
build 0.94
+ Export viewport as single image
+ Export viewport as sequence.
+ Export frames as GIF.
+ Adjustable turret rotation angle.
build 0.923
* Fixed the bug with SHP(TD/RA) PNG sequence exporter.
build 0.921
+ Export frames with current settings as PNG sequence
+ Frame info panel
* Fixed the bug with turret without shadow mode. You need to choose the palette format to make it work properly.
build 0.91
+ Tools panel with color presets
+ Game type selector
* Fixed the bug with shadows been drawed ower body.
build 0.89
^ Required files moved to assets folder
build 0.87
* Fixed bug with SHP(TD/RA) formats shadows and turrets.
build 0.83
+ Added support of SHP(TD/RA) format
+ UI revamp
+ Changable background
* UI bugs fixed.
build 0.81
+ Remapable colors support
build 0.7
+ Finished SHP(TS) format compressions support
+ Animations support
build 0.66
+ SHP(TS) compression 3 format support
* Bug with reading SHP(TS) compression 1 fixed.
build 0.24
^ Initial release
+ SHP(TS) compression 1 format support
Upcoming features:
TMP(TS/RA2) format support
 Filesize:  133.88 KB
 Viewed:  29299 Time(s)
SHPViewer0965.zip
build 0.965
 Filename:  SHPViewer0965.zip
 Filesize:  425.37 KB
 Downloaded:  1763 Time(s)
Everything not saved will be lost. :3
PostPosted: Sun Sep 26, 2010 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can't test it right now, but it looks promising.
DonutArnold
I came Surprised
Revolutionary
PostPosted: Sun Sep 26, 2010 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice tool, very nice tool indeed
I see we can also make our own back grounds as well, And it supports CnC and RA1 Properly Very Happy
The only possible suggestions I could give is perhaps a create screen shot feature however that is not necessary (it would be useful to be able to create gifs using this tool) Or the ability to read straight form the mix files.
I posted a new post linking to this over at CnC-Comm , Its not every day you get a new CnC/RA compatible tool.
Katz
PostPosted: Sun Sep 26, 2010 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE: Version 0.923
Changes:
build 0.921
+ Frame info panel
build 0.923
Upcoming features
Export viewport as image, image sequence or gif
Separate turret rotation
Separate body offset
First post updated. Sources at GIT updated.
Katz
PostPosted: Mon Sep 27, 2010 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: Version 0.94
Changes:
build 0.94
Upcoming features
PostPosted: Mon Sep 27, 2010 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
This tool is the sex! So many options :3
PostPosted: Tue Sep 28, 2010 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm lovin' it Very Happy
PostPosted: Tue Sep 28, 2010 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Really cool tool.
Though maybe i missed something, but i just wanted to open a custom SHP(TS) file and the program crashed. Sad
I'm not sure if there is a menu for this, but i miss an option to set the StartStandFrame, StartWalkFrame, WalkFrames, StandingFrames etc and an option to define at which frame the turret frames start.
So you can display the turreted TS Titan mech as well as the non-turreted Wolverine and the DTA units which have 32 instead of only 8 facings.
Here's another idea for you:
Please add a FireFLH analyser. (e.g. 3 textboxes for the Forward, Lateral and Height value and a colored red point following these values in the viewport)
You can find a tutorial "Primary/SecondaryFireFLH, TurretOffset & PBarrelLength explained" on tibweb.
Since turretoffset doesn't works in TS, RA2/YR for SHP units as it doesn't moves the turret visually ingame, you could also add a function which moves the body instead and save the SHP with this modification.
e.g. if you add TurretOffset=-100, the turret will stay in the centre and instead of being moved 100 leptons to the back, the body will be shifted 100 leptons forward along the front/rear body axis. (this was manually done in DTA already if you want to know how it looks ingame).
Katz
PostPosted: Tue Sep 28, 2010 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Please send file and Error to my PM.
Katz
PostPosted: Tue Sep 28, 2010 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: Version 0.95
GIF engine changed:
Old:____________________New:
Changes:
build 0.95
Upcoming features
PostPosted: Tue Sep 28, 2010 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Eh, maybe you should update it less frequently and with bigger patches, so people don't have to download a new patch every day Wink (unless it is a critical update)
Also, I noticed there'sa very limited selection of palettes, or have I just missed an option to load new ones?
PostPosted: Tue Sep 28, 2010 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just copy a new palette into the assets subfolder. SHP Viewer is loading new palettes automatically from there. Wink
PostPosted: Tue Sep 28, 2010 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, thanks.
Katz
PostPosted: Tue Sep 28, 2010 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update: Version 0.953
Changes:
build 0.953
* Fixed bug with SHP(TS) frame count (Thanks to Lin Kuei Ominae for submit bug)
Upcoming features
2Crimsonum
Sorry cant update this less frequently because most of updates is hotfixes for important bugs.
PostPosted: Tue Sep 28, 2010 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some more improvement suggestions.
When changing the palette, the viewer loads the whole SHP again. This can take quite a while if you have a SHP with a lot of frames (like the one i sent you for the bug report)
If possible, just change the color and don't reload the whole SHP.
When changing the palette and/or the remap color, the viewer resets to view frame 1 of the SHP. Beside that it reloads the complete SHP each time (also when changing the remap color), it should keep the currently shown frame, so it's easier/faster to compare different palettes and remap colors.
Oh and can you explain what the View/Game menu is good for? I tested all 4 and the only difference was that the remap was then purple.
Katz
PostPosted: Tue Sep 28, 2010 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah this is possible and i'm planning to redo render engine.
View\Game - choosing between game remap colors ranges (like TS have from 16 to 31 remap index, but RA from 80 to 95)
Katz
PostPosted: Wed Sep 29, 2010 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: Version 0.96
Changes:
build 0.96
Upcoming features
Merophage
PostPosted: Wed Sep 29, 2010 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent work Katz.
Katz
PostPosted: Thu Sep 30, 2010 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: Version 0.962
Changes:
build 0.962
Upcoming features
picpic
PostPosted: Sun Oct 03, 2010 10:22 am    Post subject:   Reply with quote  Mark this post and the followings unread
Hi katz, How do you make a rotating animation like this one...
GIF engine changed:
It's with shp viewer, or something else ?
Katz
PostPosted: Sun Oct 03, 2010 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. this is maded with my SHP Viewer by applying Turret on Body and exporting frames to GIF
Katz
PostPosted: Sat May 14, 2011 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Changes:
build 0.965
+ Reading APNG
Upcoming features
PostPosted: Mon Jun 27, 2011 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
moved, from TS editing forum to this place.
Mlem!
PostPosted: Wed Nov 21, 2018 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
It says "...SHPViewer0965\assets\temperat.pal" could not be found, when trying to open any sprite with it.
Is it perhaps something like an windows file permissions issue ?
[ Time: 0.1816s ][ Queries: 14 (0.0115s) ][ Debug on ]
