The time now is Tue Apr 23, 2024 12:36 pm
Tiberian Sun: UMP Merges With Tiberian Sun Client
Post new topic   Reply to topic Page 1 of 3 [103 Posts] Mark the topic unread ::  View previous topic :: View next topic
Goto page: 1, 2, 3 Next
PostPosted: Sat Jul 03, 2010 1:56 am    Post subject:  Tiberian Sun: UMP Merges With Tiberian Sun Client
Subject description: Unsticky this thread when you can.
Tiberian Sun: UMP Merges with Tiberian Sun Client
Hello ladies and gentlemen, today I would like to announce that Tiberian Sun: UMP has been merged with the new Tiberian Sun Client. All traces of the UMP's separate downloads no longer exist or have been updated to include and specify the fact that it is now part of the Client itself.
Our ModDB page has now been updated and edited to suit the Tiberian Sun Client's needs. This isn't to say that Tiberian Sun UMP is no longer an ambition, quite the contrary, we will continue to fix bugs in the original Tiberian Sun code and these fixes will be included as a part of the Tiberian Sun Client itself in the future, assuming we come across more bugs in Westwoods codes, which I think we all know is incredibly likely.
For those of you that don't know, the purpose of Tiberian Sun: UMP (Unofficial Mini-Patch) is to fix all known (fixable) bugs in Tiberian Sun.
PostPosted: Sat Jul 03, 2010 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
The reason that Attack Buggy couldn't crush infantry was to make it on par with the Wolverine. Like the Wolverine, the Attack Buggy is immune to veins as well. As well as you should include a fix for the TS Nod mission with the imprisoned commander, you have to capture a refinery while the harvester is docked, instant dump would break the mission.
Other than that, nice work!
PostPosted: Sat Jul 03, 2010 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I've tested the mission, you are still able to capture the Refinery while the harvester is unloading, you just have to be quick.
Allen
PostPosted: Sat Jul 03, 2010 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Aro, I'm going to give you heads up. Messing with the values below can have some bad effects on single player missons if you mess with them too much.
;Default Values
[General]
TeamDelays=1350,1350,2550
AIHateDelays=5400,4500,4050
TotalAITeamCap=14,12,10
MultiplayerAICM=250,200,100
MaximumAIDefensiveTeams=6,5,4
MinimumAIDefensiveTeams=4,3,2
FillEarliestTeamProbability=100,80,60
I set my Rules to the values below and I got Zerg Rushed to no end on the Nod misson "Blackout"
;Modded Values
[General]
TeamDelays=1,312,625
AIHateDelays=4000,3000,2000
TotalAITeamCap=55,45,35
MultiplayerAICM=3500,2000,1000
MinimumAIDefensiveTeams=5,4,3
MaximumAIDefensiveTeams=7,6,5
C&C in RA-1 Get it here
Paranoia
Cyborg Specialist
PostPosted: Sat Jul 03, 2010 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I would recommend against adding a multiple factory bonus as it severely imbalances the game when large amounts of helipads are constructed.
PostPosted: Sat Jul 03, 2010 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
VeteranRatio=4.0
;D
Well, there you have another point why I'm personally against insta-dump Razz
Movement speed is now consistant on clear, pavement, rough, sand and grass (Gameplay enhancement)
I know it was overly exaggerated in TS, but I'd rather keep rough and sand as the usual slow-downers, and pavement as the speed accelerator. Well it depends who wants it either way.
PostPosted: Sat Jul 03, 2010 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I know my coding and modding, that's why I didn't set retarded over the top values. For the second time: I've played all the missions from the start to the end with the UMP installed, everything works perfectly and I am yet to come across any errors.
For the second time, there is no problem with capturing refineries while harvesters are docked, it still works perfectly fine unless you're turtle-slow.
These are OPTIONAL ADDITIONS and so is the Harvester Dumping speed! They can be easily removed and reverted back to normal as I've already mentioned in the first post and in the UMP readme. On that note, I've re-uploaded the UMP with a tiny fix. If you've already downloaded it, download it again.
PostPosted: Sat Jul 03, 2010 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Great, then good work on the UMP, 'bout time TS got a UMP.
Allen
PostPosted: Sat Jul 03, 2010 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Retarded over the top values helps Skirmish mode. I already look at your numbers but I did not know if you were going go push them farther.
PostPosted: Sat Jul 03, 2010 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I wont alter the AI values again unless I feel it's necessary, but again, the AI changes are optional additions.
Anyway, I've switched the download in the first post. Be sure to re-download. Wink
PostPosted: Sat Jul 03, 2010 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Shouldn't this be in the mod announce forum?
PostPosted: Sat Jul 03, 2010 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Since it's more of a fix than it is a mod, I feel Tiberian Sun Editing is better suited.
PostPosted: Sat Jul 03, 2010 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well it's a fix still suited to your tastes. Therefore bent to your play style, it's a modification.
But, oh well.
PostPosted: Sat Jul 03, 2010 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Eh... faster harvester dumps is good, but instant dumps is annoying.
Apart from that, nice mod Smile
PostPosted: Sat Jul 03, 2010 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah its not a fix if it mods gameplay.
1) I'd much prefer to have the traditional Tiberium dumping, its just cooler and its what Tib games are all about.
2) Removing the "different speeds on different ground" isnt a gameplay enhancement IMO, since thats a pretty cool feature and should be used a lot more instead of a lot less.
3) RA2 veterancy is good but 4.0 is too low IMO.
4) MaximumQueuedObjects is debatable. IMO it adds some kind of micro-management to building things, which isnt a bad thing.
PostPosted: Sat Jul 03, 2010 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Uploaded UMP 0.1a. Simply removes all optional additions and enhancements and maintains all bug fixes from 0.1.
Volgin
PostPosted: Sat Jul 03, 2010 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see that a successor to TS 3.0 of sorts was made. I should go dig that mod out one day and make it a random gagglefuck mod... one day.
Victory!
Cantdrawbutmod
PostPosted: Sat Jul 03, 2010 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
In case somebody would try to play an old mod,what's needed to do about the patch?
Removing it completely?
Leaving any file that isn't overwritten?
Remove only specific files and leave the others,unless they're overwritten?
Something else?
PostPosted: Sat Jul 03, 2010 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well assuming this is a proper mod you're talking about, yes, you'll need to remove the UMP. This is more of a base for starting a new mod.
0.2 Uploaded, check first post for changelog.
I decided to remove all the optional additions and just stick to the bug-fixes.
Volgin
PostPosted: Sat Jul 03, 2010 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I disagree with the removal of the changes, personally. If you could spice up the gameplay and have it pull away from being GDI oriented online, I think that'd be nice. Neutral
Victory!
PostPosted: Sat Jul 03, 2010 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well the idea is to set up a bug-free TS for modders, it was never intent to be a balance mod (though I've been tempted to get carried away).
SuperJoe
PostPosted: Sat Jul 03, 2010 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've left MaximumQueuedObjects bit lower (15) since TS has a very annoying bug. If you run out of money while a unit is about to begin its construction, the construction goes on hold state and doesn't continue building even if you get money again. Too many times I've ordered 10 tanks only to come back 5 minutes later to notice only 1 have been built. A lower limit might make you check the construction progress more often.
PostPosted: Sat Jul 03, 2010 10:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the third time: I've removed all optional additions (I'm getting really sick of saying those two words).
As for the build Queue bug, that's always existed, regardless of how great the value is. It's in Vanilla TS and Red Alert 2.
SuperJoe
PostPosted: Sat Jul 03, 2010 10:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I thought raising this limit was part of the core changes. Personally I do think MaximumQueuedObjects should be raised by this "patch" since 5 is just an artificial and quite annoying limitation. Was just saying have to be careful with the limit because of this bug. Sure it happens in Red Alert 2? I don't ever recall having it happen in there.
PostPosted: Sat Jul 03, 2010 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The bug is always there regardless of the value (unless you only allow yourself to queue one unit at a time like in TD), it's annoying but there isn't much that can be done about it. Yep, I'm possitive it's also in Red Alert 2 (Not sure about Yuri's Revenge) cause it's cost me more than one game online.
Cantdrawbutmod
PostPosted: Thu Jul 08, 2010 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
After trying the patch,I found all my skirmish maps going in english.
I figured it was because of missions.pkt,so I went around in .mix files and gathered the data to make my own missions.pkt with the french names.
I know the quantity of persons interested by this AND coming in this forum must be incredibly low Laughing ,but I still share it just in case.
missions.zip
 Filename:  missions.zip
 Filesize:  1.18 KB
 Downloaded:  1010 Time(s)
Cantdrawbutmod
PostPosted: Sat Jul 10, 2010 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Something that bothered me with this patch is the harvester harvesting animation.
That green smoke isn't good,it looks more like tiberium gas,and it feels really wrong when harvesting blue tiberium.
I tried to put back the old harvestr.shp,and I find it better: gray don't feel weird,and it even seems smaller,like if it had better transparency (maybe it just blend better with the harvester Confused )
edit: I checked in that some more,taking screenshots and comparing them.
After all,there doesn't seems to be any real transparency difference.
I looked for things in rules.ini or art.ini,workarounds and/or enhancements using the wrong palette,that would have been proofs that it would be a hack rather than an error,but I didn't find those.
Yet it's still possible this "error" was made of purpose (I don't know if it would be hard to get the same gray on the normal palette),there are unfinished things,hacks and workarounds in this game after all.
I will keep the "wrong palette" version.
I don't create a new post to say all that,since considering this fix right or wrong will depend on the feedback about it.
Last edited by Cantdrawbutmod on Tue Jul 13, 2010 12:34 pm; edited 1 time in total
PostPosted: Sat Jul 10, 2010 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are aware that the harvesting animation was actually in the wrong palette right? The green color is how the animation was originally supposed to look. But of course you could always change it back to being in the wrong palette if that's how you prefer it.
PostPosted: Wed Jul 14, 2010 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, a bug you need to write off is all the mutant infantry (MUTANT, MSGT, and MWMN) use a fire anim for their weapon while they still crawl and thus need it removed. The Mutant and Mutant Sargent SHPs have a firing anim build in but the Mutant Soldier needs one, I believe I posted a fixed SHP in the SHPs section here that added a firing animation.
Dug through the SHP forums and found it here.
GameMaster0000
PostPosted: Thu Aug 05, 2010 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I just notice that another problem with this patch icon not darken when build building.
I check around problem is from "darken.shp" in ecache02.mix. Is this mistake?
 Filesize:  55.54 KB
 Viewed:  113514 Time(s)
Tiberian Sun : True Power - Reality Power Of 5 Factions...
Paranoia
Cyborg Specialist
PostPosted: Thu Aug 05, 2010 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
That cuts down a heap of lag. Certainly is not a mistake.
PostPosted: Thu Aug 05, 2010 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, TI has a similar fix. Anyhow, you may want to change it to something so you can see if you've already build a hero or the hero is dead yet. Other than that, basic building has no use for it.
FurryQueen
PostPosted: Thu Aug 05, 2010 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
So that's what darken.shp was for. I never actually realized its significance.
KGR | AT
AZUR
Discord: theastronomer1836
Steam
PostPosted: Fri Aug 06, 2010 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Sat Aug 07, 2010 3:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not a mistake, it prevents a serious lag issue occurring in-game.
GameMaster0000
PostPosted: Sat Aug 07, 2010 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it happen only on MP? I won't notice any different on lagging with that.
PostPosted: Sat Aug 07, 2010 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
It happens during both Singleplayer and Multiplayer for me.
PostPosted: Sat Aug 07, 2010 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, try building pavement a few times and you should notice lag.
GameMaster0000
PostPosted: Sat Aug 07, 2010 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe just my PC, I never have issue of lag that cause by darken.shp. I change game speed to 1-6 speed I never notice any lag.
PostPosted: Sat Aug 07, 2010 10:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me neither, but some have much more problems with lag.
And not only caused by darken.shp, but by transparent stuff in general like transparent explosions or fading out traileranims.
The same is true for the bright glow effect caused by explosions. While I don't have any lag at all even with hundreds of them appearing at the same time, do others from the TI staff have lags with these too, that's why we had to disable the weapon glow completely for TI.
PostPosted: Sat Aug 07, 2010 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's even been in C&C1 and RA1, before the build queues. If you have no money at the moment a unit starts building, it goes on Hold. Heck, in Dune II, automatic construction continuing didn't even exist; you ALWAYS had to manually restart them if they stopped due to low funds.
GameMaster0000
PostPosted: Thu Aug 12, 2010 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Found more bug on FS mission
- FS Nod mission 7, CABAL's core house is no power result is Firestrom,Laser Fence and base defence is shutdown.(Both UMP and vanila)
- FS Nod mission 8, when CABAL house finish build his base. Result is Low power due not enough power plant.(Both UMP and vanila)
- FS Nod mission 9, Elite Cadre no icon.(Only on UMP)
GeckoYamori
PostPosted: Thu Aug 12, 2010 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
So it was the darkened icons all along that caused such massive slowdown when building stuff? I never knew that.
PostPosted: Thu Aug 12, 2010 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
GameMaster0000: Not sure if he cares much about pre-existing mission bugs... this patch is made as clean slate for mods.
PostPosted: Fri Aug 13, 2010 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup. Not just the darkening layer, but also the clock animation that are drawn on the icons slow the game down (not that significantly in older computers).
Exley
PostPosted: Tue Jun 07, 2011 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
erm, I have a questions
this pack has missions.pkt and multi01.pkt
where do they go, as in what MIX name ?
also does UMP allow normal play of TS and FS as before ?
(I ask coz of now merged all rules into 1 file)
PostPosted: Wed Jun 08, 2011 4:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Simply copy the patch (all files of it) into your TS folder. There is no further editing necessary to make this patch work.
Yes normal TS and FS play are possible. The only difference is, that you can now use the firestorm units in TS too.
Exley
PostPosted: Wed Jun 08, 2011 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm how come ecache02 isn't needed in expand02 ? #Tongue
and will it work fine if I put it there ?
xXHunterKillerXx
PostPosted: Mon Jun 20, 2011 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you don't mind me asking, what exactly are the contents of missons.pkt and multi01.pkt?
EDIT: Scratch that. I got it. lol
Tiberian Sun: Outbreak
Exley
PostPosted: Sun Oct 30, 2011 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
small heads up
UMP 0.2 is missing UnitCount= tag in Multiplayer Settings (rules.ini)
and there is cabal obelisk image overlaping
also UMP has on many places this:
Tag = value
instead Tag=value
(spaces)
also I don't know if this is hardcoded (LKO might know more)
but [Tentacle] weapon Range is set to 15 which makes Floater
shoot from distance and kill nothing but gets stuck far away from target
(also farts massivly which lags game)
reducing this to 2 helps
Post new topic   Reply to topic Page 1 of 3 [103 Posts] Goto page: 1, 2, 3 Next
[ Time: 0.5567s ][ Queries: 14 (0.3385s) ][ Debug on ]
