The time now is Thu Apr 25, 2024 7:32 pm
Enabling the 4th Tiberium
Post new topic   Reply to topic Page 1 of 1 [48 Posts] Mark the topic unread ::  View previous topic :: View next topic
PostPosted: Sun Feb 24, 2008 11:30 pm    Post subject:  Enabling the 4th Tiberium Reply with quote  Mark this post and the followings unread
This tutorial will show you how to reactivate the 4th tiberium so that it works properly. Before starting you must have a Hex Editor, one can be found here
Once installed open up Game.exe, make sure you are not opening Sun.exe
Once opened search for this 00244DF9. Once there you will see this.
See the 01? Change that 01 to 12. That way the game reads 12 frames like normal tiberium, instead of 1. It should look like this now.
That is now fixed, you can copy game.exe and do this and rename it so that you have a custom game.exe for your mod. Btw the game will still look for the BTIB code, so it if you want to change the image change BTIB01-12.
That's it. Smile
Key Words: #Tutorials #Modding #TiberianSun #Firestorm #ExeHack #HexEdit
PostPosted: Mon Feb 25, 2008 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Idiotic quiestion... what does that do exactly? 12 frames for what?
PostPosted: Mon Feb 25, 2008 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
each tiberium plant has 12 growth stages implemented in 12 frames in the shp. Now the game can use all 12 frames, thus make the tiberium grow and (hopefully) full harvestable.
Last edited by Lin Kuei Ominae on Mon Feb 25, 2008 12:36 am; edited 1 time in total
PostPosted: Mon Feb 25, 2008 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Works completely, me and TSHyper have tested this. Wink
PostPosted: Mon Feb 25, 2008 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
is this for game.exe version 2.03 only?
i found this specific location at hexadress 00244cbf and use v2.02.
PostPosted: Mon Feb 25, 2008 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm pretty sure it's for all versions, I'm not positive though.
PostPosted: Mon Feb 25, 2008 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
No, they will not be the same addresses for each version, and why do you use 2.02 LKO?
PostPosted: Mon Feb 25, 2008 12:51 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm... yes why are you using 2.02?
Roaches
PostPosted: Mon Feb 25, 2008 3:15 am    Post subject:   Reply with quote  Mark this post and the followings unread
Ah...this screenie brings back the old memories of ROM Hacking...Makes me wanna work on my own patch. Very Happy
Everybody knows a mod that doesn't update every ten seconds is dead.
Robopope99
PostPosted: Mon Feb 25, 2008 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for this, I find this tutorial very useful. nice work Very Happy
PostPosted: Mon Feb 25, 2008 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Your welcome
However in HyperPatch TSHyper will allow many types of tib. Smile
PostPosted: Mon Feb 25, 2008 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Depending on what 2.03 does to 2.02, it might be possible this hexy works for both.
Since it's apparently been tested for 2.03, use in other executables is not recommended.
PostPosted: Mon Feb 25, 2008 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
...why do you use 2.02 LKO?
because the patch wants registry entries and i haven't "installed" my TS. I just have the files on my hdd and play it this way.
So i never thought it would be necessary to install TS again just for this patch, since all the fixes are for multiplayer only while i was never playing online.
PostPosted: Mon Feb 25, 2008 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
so its possible to add in more "growth" frames?
PostPosted: Mon Feb 25, 2008 2:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
_
PostPosted: Mon Feb 25, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice tutorial joshy for enabling Cruentus, now I just need to make it harvestable too Laughing
I hex edited ETS v3.40 r0019 based on TS2.03 and it was located at the exact same place as in your screenshot of your hex editor.
I cant provide a screenshot at the moment but I can confirm that this tutorial works (I used frhed v1.0.56 for hex editing the ETS version of Game.exe with no trouble at all)
I changed what tiberium type the blue tiberium tree/bush spawns in firestrm.ini by changing TiberiumToSpawn= to 1 on [BIGBLUE3]
0=Riparius ;Green Tiberium
1=Cruentus ;the fourth type, the one we enable in this tutorial
2=Vinifera ;Blue Tiberium
3=Aboreus ;Third type, default is blue color and is mixed with vinifera on several official maps
PostPosted: Mon Feb 25, 2008 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
LKO, well, if you ever need the 2.03 files on there own, then goto http://www.ts-recoil.ppmsite.com/ts_patch/
damn, i totally forgot that i already have them. You posted them on tibweb a quite long time ago.
Anyway thanks for the link. I'm installing the patch right now.
PostPosted: Mon Feb 25, 2008 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably, give it a try Wink
PostPosted: Mon Feb 25, 2008 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also, have to add credit to the pd-mister, he was the one who found it after i bugged him #Tongue
Renegangsta
PostPosted: Mon Feb 25, 2008 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
so how the hell do you use the fourth tiberium? will it show up in FinalSun's tib list?
and "The 4th Tiberium" sounds like a band.
With sadness in my heart and joy in my mind
View user's profile Send private message Yahoo Messenger Account AIM Address
PostPosted: Mon Feb 25, 2008 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have to give you and pd credit for getting me into assembly. Thank you. Also for showing me this too. Thank you again. Very Happy
In finalsun I think it is under all overlay. It will be labeled BTIB01-12 you can just select that a put it there. Also you can give tiberium tree TiberiumToSpawn=1 so that it spawns the 4th tiberium.
DaFool
PostPosted: Mon Feb 25, 2008 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
lol, how the hell did you know which one was the right one when all it looks like is numbers?
PostPosted: Mon Feb 25, 2008 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Magic...... Rolling Eyes
PostPosted: Tue Feb 26, 2008 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
DF, by disassembling the games executables...
Tiberian Enigma
PostPosted: Mon Apr 06, 2009 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
this, what exactly does this statement mean?
and another question, is this 4th tiberium the elusive red tiberium that ive heard about but never actually seen?
PostPosted: Mon Apr 06, 2009 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey. Smile
Well, what I meant was, the game still searches for BTIB when looking for the tiberian images (Those tiberium shps) so if you want custom images for the 4th tiberium you must name the image name accordingly
As for the 2nd question.. I guess. #Tongue
Tiberian Enigma
PostPosted: Tue Apr 07, 2009 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, well then i guess if the default is red then i will leave it red. it makes sense to have all forms of tiberium playable since they mention it numerous times in the game, yet there is almost none to be found
PostPosted: Tue Apr 07, 2009 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, in the game there are 2 blue tiberiums, but you can't really tell the difference. The lighter one is worth more I think. I think that's how it was, I may be wrong.
Revolutionary
Location: Scotland, starting a Revolution Cameo: metricon. Posts:???
PostPosted: Tue Apr 07, 2009 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
you can only tell the differance playing the game
the 2nd blue tib appears as red on some ww maps in the map editor and in game it is blue but shown as green in the mini map
Creator of TS:BoB and some other things that might be good when finnished.
Tiberian Enigma
PostPosted: Tue Apr 07, 2009 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, but i think theres an actual red type of tiberium that is mentioned, but not activated ingame. ive seen pics of it on maps, so this might be it, i think its called cruentus.
PostPosted: Tue Apr 07, 2009 9:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
In the Rules its commented as Cruentus, but its colour is set to NeonBlue, people mod the maps to enable it again with a Burgundy colour.
Ah yeah, that's right.
Deformat
PostPosted: Wed Apr 08, 2009 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a newbie tutorial out there?
PostPosted: Wed Apr 08, 2009 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
No
PostPosted: Wed Apr 08, 2009 7:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Duh, someone pass me the 2.03 exe...I hate having the TFD one -________-
Tiberian Enigma
PostPosted: Thu Apr 09, 2009 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
ugh, it sucks that westwood left so much stuff out of the final game, but good that they left the code so we can unlock the mystery!!!!!!!!?!?! if only there wasnt so much confusing stuff tho!
Revolutionary
PostPosted: Thu Apr 09, 2009 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
@Tiberian Enigma
ah but the 4th tiberian is on some maps as a funny coloured big blue
; This is the big tiberium crystal.  It does not grow or spread, is impassable and is explosive
; Not currently in use in TS (AI)
[Cruentus]
we are just abusing left out code to creat something more usefull (who needs the big blue thing when it causes lan errors (aparently) and firestorm adds it as a special tib tree
PostPosted: Sun Jun 21, 2009 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think it was some single player maps? I don't recall.
Abusing code? It just changes the frames from 1 to 12.
PostPosted: Sun Jun 21, 2009 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, its not abusing code, WW changed/hardcoded the frame count to 1 becuase it was not ment to have a visual growth becuase it was a solid rock substance.
WW hardcoded a lot of things becuase the coders always used to change settings and would conflict with each other, so some things are hardcoded, aswell as in the later patches it was easy for them to just write a a few extra lines of code in the source than edit the rules.
PostPosted: Sat Dec 26, 2009 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry for the bump
Are you sure you have to use a "12"? The number is afaik in hexadecimal and 12 in hex is 18 in dec.
So shouldn't it be 0C instead?
I've tried 12, 24, 0C and 06. For 12, 24 and 0C i haven't noticed any difference. Though 12 and 24 could have forced the game to try using 18 and 36 frames, which don't exist and might cause an IE in rare cases.
PostPosted: Fri Mar 19, 2010 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
0C
Correct, I was thinking in decimal, not hex for when I posted this. I don't even remember if it works. Confused
PostPosted: Mon Oct 18, 2010 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry for the bump, but does anyone know the hex offsets for the other tiberium types?
I somehow have the impression, that WW gave them a wrong frame number too.
If you look at the screenshot in the first post, you can see at offset 244dd0 (first value 2 lines above the red marked) that there is a 11.
While tiberiumpatches do have 11 frames (when count from 0), this should still be a 0B, as 11 in hex is 17 in dec.
Maybe this also explains why new spawned tiberiumpatches (e.g. next to tibtrees) always appear as stage 6 tibpatches instead of the first/smallest patch.
PostPosted: Mon Oct 18, 2010 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Could this also have something to do with the Tiberium shadows? The shadows are displayed incorrectly, so they appear a few pixels right of the overlay. It could, however, be that the shadow frames are displayed in an incorrect order, and therefore a small Tiberium overlay has the shadow of a near-full grown Tiberium patch.
PostPosted: Tue Oct 26, 2010 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
What exactly is the 4th tiberium? Can it be harvested and does it have any special properties like blue tiberium has (explosive, gives more money)? Also does it look different than normal tiberium or is it just normal tib colored red?
Revolutionary
PostPosted: Tue Oct 26, 2010 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 4th tiberium with out this edit is the beta version bigblue tib tree in firestorm. It is basicaly the Bigblue crystal from FS but i supose to explode if shot at and isnt harvestable as well as spawn tiberium (i say beta as it is not properly used but does appear on some maps, irronicaly on several FS map which should use the new version)
The 4th Tiberium after this edit is basicaly changing the 4th tiberium type's graphics from being looped (for the bigbule's animation) in to a functioning tiberim crystal like the excisting 3 (blue, green and red which is realy green but shows up on the radar a blue)
Thats right isnt it, i need to get my notes on this out again and finnish my guide...
PostPosted: Wed Nov 23, 2011 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
^^that's not quite correct
The hex-edit does nothing else than telling the game to use 12 instead of only 1 frame for Cruentus (the 4th tiberium).
Due to this, the tiberiumtype is able to be spawned by tiberiumtrees (TiberiumToSpawn=1), as these always create stage 6 patches, which previously weren't possible since only stage 1 were coded as the max.
Due to the higher number of stages/frames, the growth and spread logic is also working.
The hex-edit doesn't changes any graphics or properties.
All other properties are set on the BTIB01-12 Overlays (index 28-39 in the Overlaytypes list) or as usual on the [Cruentus] Section.
The BTIB Overlays normally have Land=Rock, which makes them impassable and not harvestable.
If you change these overlays to use the same settings as the other tiberiumtypes (Tiberium=yes, Land=Tiberium), the BTIB becomes a fully working tiberiumtype.
Even without the hex-edit, you can still make Cruentus harvestable, by simply changing the Overlays. The only difference to the other tiberiumtypes is, that this tiberiumtype then can't be bigger than stage1 patches.
PostPosted: Sun Dec 04, 2011 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you do all this
does it still crash a game ?
how did we end up here ?
this place is horrible ...
smells like balls ...
PostPosted: Fri Apr 13, 2012 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, Cruentus is hardcoded to have only 12 overlays for the normal ground, but no overlays for slopes (BTIB13-20 for slopes are not supported).
Thus even with the hex-edit applied, the game would crash if Cruentus is placed (in FinalSun) or spawned (ingame via animations) on slopes.
However Cruentus doesn't grow/spread on slopes alone, so it would not cause a crash if used correct.
(sorry for bump #Tongue )
[ Time: 0.2070s ][ Queries: 11 (0.0096s) ][ Debug on ]
