Posted: Fri Aug 24, 2007 4:28 pm Post subject:
Concept Drawings
Subject description: Post all concept art here
Not sure really wot to say but, Here i have uploaded 3 concept drawings i have drawn, 1 drawing is clearly a modified Orca which i have called the Orca Mk III, designed for exescive speed and manouverbility, advanced weapon systems and top of the range cockpit! the others r rough designs sketched from my head!
ahhh. ok. resized alot better. the 4th are the best, because very easy to read, alot nicer, the rendering helps but . the other sketches are..very rough. and cluttered. makes it hard to read. _________________ Delirium.. QUICK_EDIT
Thank you. after i uploaded these i headed over to the TS:RO (Which i am eager to play) and looked at all the concept drawings that Corsair and other members created, i really need to no what pencil there using!! And yes most of my drawings are rough rushed sketches as i dont get much time to sit down and draw! I know for definete that the 2nd drawing will become a voxel as i shall attempt it using VXL Editer III, but itll ave to wait till i get my pc fixed QUICK_EDIT
Too sloppy. If you're not good at drawing crisp, clean lines, use a ruler.
Also, I suggest for all concept artists to use typewriter paper (the older the better - I use some stuff from the 1970's), and black gel finepoint pens. Best materials you can use. _________________
[quote="Bobingabout"]I've got more naruto porn than furry porn[/quote] QUICK_EDIT
Joined: 01 Feb 2007 Location: National Reference Laboratory for IPNV
Posted: Sat Aug 25, 2007 5:19 pm Post subject:
Wow these are quite good, and also it's nice to meet a fan of our mod .
I'm guessing that you would prefer to know what does Corsair use to draw, though anyways I'll tell you what I use
-A normal graphite 6b hexagonal/trigonal pencil (I don't like the round ones; to make the basic sketch lines, and shadows, though most of them get lost during scanning )
-A Parker Jotter mechanical pencil 0.5 mm (I like it's design, and it's quite comfortable; I use them to finish the small details) Though I used a Pilot Shaker 0.5 mm mechanical pencil, until it broke. Anyways sometimes I would use a pen to finish details.
-An eraser; BTW you should never use a plastic eraser.
-A sketch book
That's what I use, basically. If you want to know what Corsair uses, I'm quite sure that he uses only a 6b pencil and white printer paper.
To answer how do we draw the human shape, just use a drawing dummy, I used one during art classes in school, though it's better and cheaper to internalize it (check this), as the dummy itself will become a burden when you try to draw non human shapes, or deformed human shapes.
BTW, don't use a ruler, they make the drawing look forced and unnatural, even if the drawing should be an object; rulers are only advised if you're doing technical drawing, and not concept art.
Finally, we were discussing to make a fan art topic at RO (can't remember with who, I think it was Corsair), but we concluded that it would be useless if we don't have any; anyways feel free to post them on the suggestion topic, if you think that your idea is good enough to be included in the mod (though I would prefer them to be posted as image links and not attachments as it would make them easier to move later ) in this way that topic would get used (the public one not the staff one). Or you could send them to me (preferably), or to another member via PMs. QUICK_EDIT
I think you are being overly harsh there, they aren't particularly bad as far as fan/modder concept art work goes. I've seen people post much worse material than this. It may not be up to professional standard, but its certainly more than acceptable for a mod concept art IMO. QUICK_EDIT
I'm not being harsh, I'm giving the dude some helpful advice. _________________
seems like you labeled a lot of crap just to show off... _________________ 0h noez!11!!! one 11!! U just p00rd n00bs@uc3 a11 0v3r my l33t sk1llz!!!!!!11one!!111!!!one111!!!!!!!
[img]http://ppmsite.com/forum/viewtopic.php?t=16541[/img] QUICK_EDIT
Thanks for all ur feedback and the tips! And i dont mind the odd critism:D. I use printer paper and pencils of h grade or below, But sinse Machine mentioned somthing about a mechanical pencil, i have dug it out and have started on some Mobile artillery bombardment hover vehicles. I will upload one here soon, rest of my drawings i will probaly submit to the TS:RO mod:D Ill try to minimalise my outragous texturing of the lines (I personally balme the pencil). And yes i do tend to write aload of jiberish, but its only to make the drawings look busier! QUICK_EDIT
Hey, don't worry about it bud, pencils always produce rough lines, even with a ruler, they still look shit scanned.
Most pens do that in another form - ink bleeding. Gel Pen's are the only ones that don't do that. Even ballpoints have some nasty distortion upclose.
Use gel-pens if you really want nice clean lines when scanned, otherwise, you're going to have the problem with any writing utensil! _________________
Posted: Mon Aug 27, 2007 10:23 pm Post subject:
@Alexander C Bukington:
I was just trying to make a point, as I think that it isn't really important what you use; what makes the difference, is how you use your "tools".
BTW the pencils I mentioned are quite common, in other words, nothing special.
@02nwilson:
BTW I did like the style you had in the concepts that you showed here (well, with the exception of C&c wars-orca.jpg), I think that you gave to them your unique style, which IMO is quite better than to imitate someone else's style . QUICK_EDIT
Cheers Machine. You are right, every one to there style! I will upload more when i find somewhere i can upload them instead of making them attachments! QUICK_EDIT
Ok here are the 3 Hover Arty's which appeared when i frew my pencil at the paper!
2nd design, this design had exeptional Radar capabilties but lacked on stabilitie when firing artillery barages! Note that the Sam is configured for strenthened lock ons
Filesize:
24.06 KB
Viewed:
23047 Time(s)
3rd design, Similar to the first design as it has to deploy to enable full use of the artilley. When in a mobile state the Missile rack is enabled.
Filesize:
24.6 KB
Viewed:
23047 Time(s)
My first design. Here you see the Arty in its deployed state, showing use of both, artillery strike and high perfomance sams, when in a mobile state the rocket pod on the far side is enabled. Due to weight restrictions only 2 high perfomance SAM missiles
@ Don95: Thats impossible, these have only just been made public sinse i joined which wasnt long ago!
Oh and come on people i want to see some of yours up here, not just mine!
Here is its link http://www.cannis.net/cannisrules/popups/orcb.png .And whether you have thought it by yourself i have a doubt Last edited by Don on Wed Aug 29, 2007 4:55 pm; edited 2 times in total QUICK_EDIT
I must say, O. Wilson. I think some of the terrestrial vehicles you have are excellent. They should really exist in voxel form if this community had any drive left in them.
Um, it's called concept art, not concept drafting for a reason. The idea is to have an artistic basis for in-game or in-use higher quality art assets later (like costumes in movies or set designs). They're not exact blueprints. The lines don't have to be absolutley precise to still convey how the general idea of the unit.
I mean, hell, even a good bit of professional concept art for games has fairly sketchy lines, or lack of percision.
Nobody made you art czar, even if you use your mom's old typewriter paper and think you're some hotshot because you used a T-square once in school.
This is the kind of attitude you cock that makes everyone and their mother despise you on forums. The exact reason why people flip out at you for no reason later. _________________
Cheers Rattus, Right i have managed to draw up three Civilian structures, 1 outpost, 1 refinery and 1 gate with civilian's walls! Also the drawings like the refinery feature there respective vehicles! Also its my fisrt attempt of drawing a human but there it is!
Since the discovery of tiberium and tiberium weeds, strastic actions have been taken to stop pollution in some of the sites via building huge walls, Millions of pounds spent on Alcos Huge Concrete walls quoted to take the force of 10 tsunami's, but there
Filesize:
51.21 KB
Viewed:
22933 Time(s)
This a Civilian Refinery, These refinery's are able to store more than what our refinerys can store, in the basement of these refinerys are 8 Tiberianproof tanks which store the purified tiberium until it can be processed into funds. Also you can see the
Filesize:
61.19 KB
Viewed:
22933 Time(s)
This is a Civilian outpost, Supplies are kept here along with armed civilians. This structure despite its appearence in size has a complex below the ground and many tunnels linking to other outposts!
Filesize:
56.12 KB
Viewed:
22933 Time(s)
_________________ Civilian Airbourne Division.
Just a bunch of Gunships
\m/ "Are you dead yet!!?!" Children of Bodom \m/ QUICK_EDIT
Seriously dude, enough of that. He didn't steal anything or base his concepts on anything else. So just give it a rest.
I'm really liking these latest concepts, 02. The last arty pic looks ace. Good job with the human, after drawing for... about 9 years now, I still can't do people for shit.
Alrighty, let's clear some things up. First off, I picked the shit up from a friend of mine who dug the stuff out of one of his little urban explorations... some abandoned office building I think
Next off, I by no means am trying to be an art czar, I'm providing my opinion of how he could improve upon the work. Making things look cleaner and crisper allow people to see the detail more easily. When using a pencil, it's pretty much necessary to make lines as clean and detail as sharp as possible, or else it can look pretty awful when scanned in. I've learned that the hard way from my experience with graphite art, and was merely sharing my view on how to improve the visual quality of his scanned works. _________________
Huzzah for completely missing the point.
Where you got it is irrelevant. Whether you swiped it from your dad's paper collection, your mom's old typewriter, a friend gave you it.. it's unimportant.
The fact that you're all "I r teh Prime, I r Gawd" is Ratti's point. Most respected people, excluding Banshee + the admins/mods, do not like you. Or, more accurately, your attitude. Yes, your work IS good. You're actually, iirc, the first/only person to truly put that much work into recreating the Soviet side of RA2. You seem to think that automatically propels you to god status, similar to a HL Xen jump pad. _________________
Ok this is my jumjet Commando, The drawing is alittle faint as im using a different scanner atm. He/She is equiped with a flame thrower and has a rocket pod with its targeting equipment on his/her other shoulder.
Dude, you have skill, I'll give you that. Certainly at shading.
But something just lacks about your stuff, man. I can't really figure it out, but perhaps it is the flatness of it... Try bolding outer lines (The shape lines, not the detail lines) as I do in drafting class, it can really make a difference... _________________
Posted: Sat Sep 08, 2007 9:43 pm Post subject:
It's good, but the human shape is not right, it looks quite catooney and retro, like something that came from Astroboy or similar. The arms and legs are too thin when compared to the body; or maybe he's just too fat. The hands are fine. About the legs, you need to give the pants more textures, as it looks quite weird, just too plain.
Finally don't give flamethrowers to GDI units, as it's not their style.
BTW I like your previous work, specially the aircrafts QUICK_EDIT
yea aside from human anatomy.. I think the design of the outfit is a little too cluttered/bulky for a jumpjet commando type unit.
considering the unit is a more of a hit and run type of unit than a brute. but maybe thats what your going for. A jumpjet brute..that would be interesting.
but anyways, try playing around with different designs. sketch out roughs and play around with the placement and aesthetics, look at other things that are aerodynamic and incorporate that feel to this design to convince us.
also approach the design with this in mind, how is this going to work ingame? does it fit? style? balance? etc etc _________________ Delirium.. Last edited by Ickus on Sun Sep 09, 2007 8:21 pm; edited 1 time in total QUICK_EDIT
Hmm, yeh that is a point! Thats really the first full human ive drawn and so i need a lot of practice buit i shall eventually get there, The Comando was purely to outdate the Ghost Stalker since i believe that since he is mutant he should stay like that (It would be that way if i decide t make a mod) As in balance's i believe that NOD's side is well unfair since it has 3 super weapons and a super unit and GDI only have 2 super weapons and 1 special unit! Also the Commando would never land, he would if you like be a hover unit, if he walked he would be two slow due to the missile racks wait, I could mabye exchange the flame thrower for a Heavy assault rifle or small railgun. _________________ Civilian Airbourne Division.
Joined: 08 Jul 2006 Location: in your closet... Post = true
Posted: Sun Sep 09, 2007 10:22 pm Post subject:
If I am correct, everyones invited to post Concepts? If so - I got some too.
Theyre old or just wont be used at TO, but you may enjoy them
The Spyder, a fast, spiderlike, lazerattacking infantrykiller. It was desidet that this wont be used due its similar look to the Cnc3-buzzers. Hell - didnt even know of them back then
Really, this Swat-transporter is an old thang. The oldest concept I drew, to be true - it was my suggestion how to let the TO civilian Urban SWATtransporters look like.
The new Wolverine - or so it was intendet to be. Was disliked because of its round shape. Looks more like Nod than GDI. But still a nice vehicle.
I tried to rework the "powersuit". The first Wolverinetrials which could be seen at some specialtrailers at the CnC:TD-cds...
_________________ audiopulse sagt:
your raging arse is creating storms?
Luke | CCHyper sagt:
yup, neptune size! QUICK_EDIT
FINALLY SOME ONE ACTUALLY ADDED THERE OWN CONCEPTS!!!! Thanks Audiopulse that is the exact reason why i made this topic, so that everyone can share there material, I love the rendering and the wolverine looks classy!
EDIT: Oh and slowly but surely im running out of ideas, it seems that all my drawings tend to look too similar and i cant think like i did when i drew those concepts! But there are some i havent shown yet!! These include a Hover tank (Nod design which they obtain from the tacticus which is equipped with a daul laser cannon, a huge Hover mammoth design for GDI which has the improved state of the art Railgun's and new to the weapons rack, GDI's very own Napalm missile bombarment, these huge missiles lauch from the turret and deal deadly damage to the NOD scums ( A simple stand in for the Napalm airstrike from C&C) Another addition to Nods side is a mobile obelisk, this deployable tank deploys into a mini obelisk which holds 3/4 of the power of the full sized defence, Also there is the addition of a new helicopter that which follows on from the longbow! Thats enough said! _________________ Civilian Airbourne Division.
@ 02nwilson: o.o post them!...also research. google. yahoo...just look beyond what is already been done. try out more organic concepts.or a new style.
I like the spyder. It has a certain appeal to it. I definately can imagine it animated.
Lol @ SWAT car, totally pimped out , I also can imagine a squad of those blockading traffic, smashing through cars and mowing down...unlucky protesters. ;_; _________________ Delirium.. QUICK_EDIT
Posted: Tue Sep 11, 2007 6:16 am Post subject:
Cyborg Rex
Well, was taking a break from my 3-d modeling I had this silly concept, Dino-riders kinda vision. where Kane decides to open his own theme park, but evil GDI wants to shut it down..
anyways. its a R/C rex with a fricken laser beam on its head! mini-guns and mechanized razor claws for those close encounters, plus armor-plated and tiberium-powered.
Frickin Loving that Rex!!!! Keep em comin, meanwhile heres some that i said i would upload and nearly the rest of some old stuff. I know i put NOD HEAVY MECH on one but lets just say they stole it
Edit The first mech is my favourite and could turn up in voxel form in the near future! _________________ Civilian Airbourne Division.
And more, This time i have made a Tiberian Wolf (simple design) and a mutated cyborg! Also there are plans for the mech i have drawn.
Offtopic: Would it be possible to make a unit upgradable by using component tower logic? Build as structure then undeploy? with the upgrade? _________________ Civilian Airbourne Division.
Joined: 07 Mar 2006 Location: In ur BIOS, Steeln ur Megahurtz!
Posted: Sun Sep 16, 2007 7:44 pm Post subject:
If the upgraded building would undeploy in a new unit type, than it could work. dont quote me on that though. _________________ Please, read the signature rules of the forum. QUICK_EDIT
Design of Cyborg Reaper,i try to rid of spider desigh from ROS and i get insprise from Necron unit in WH40K [ i forgot it name] ythat why it's going to be hover.
ROS Temple Of Nod. because it's very hard to model.[for me] i need to improve my 3d skill to make it.
Core Defender,first i design it equip dual rocket pod,but rocket doesnt fit for Cyberbernatic Army anymore finally i change it to be electric cannon.
Cybernatic architecture concept.
Hyperion Ultimate Artillery Mech for Faderal Side.
and another project drawing.
thank for this topic,this will be useful when my idea is deadend. QUICK_EDIT
Joined: 29 Aug 2007 Location: Village of Creston, British Columbia.
Posted: Sun Sep 16, 2007 10:15 pm Post subject:
All this stuff looks really cool. I really should get back to drawing concpet art for my own projects, I might have something to show though. _________________
