Posted: Sat Nov 04, 2006 11:27 pm Post subject:
YR Online problem
In my house, we have two computers with same IP adress and same CD-Key.
I can play online fine, but not the other computer.
If he goes to Internet and then Custom Match, it says, "Make sure you are connected" and when we click on network(with Gamespy arcade), we cant se eachothers. Why?
I have tried to re-install both RA2 and YR, he is using RA 1.006, YR 1.001 and RockPatch 1.08 SE. QUICK_EDIT
Hmm...let's see...if two people with the same body and the same name chatted you up, would you be able to tell them apart?
Seriously man...you said yourself they look the same. You can't play multiplayer with a single version - and as far as the game (or XWIS) is concerned, there is only one - the one with your IP, and your CD-key.
And even if you managed to convince the server to accept the same IP twice (I think I've done that before, the whole house is behind a router), you wouldn't be able to play from two versions with the same IP. EULA says so.
Same goes for network. IPX not-see issues are usually a question of target network, check your advanced network options (ignore all the dumbass "just set it to 0000" tutorials and simply select the correct network adapter and correct network). But, like I said - even if you see each other, you can't play without a second CD-key - 'cause no matter how licensed your first installation is, the second one is definately unlicensed.
One last thing: All of this was quite obvious, a no-brainer, and common knowledge. I just replied 'cause I'm bored and have nothing better to do. So next time, search before you post. And think, too. _________________ #renproj:renegadeprojects.com via Matrix - direct link QUICK_EDIT
thats false, i have played many times with same CD-Key and same IP, it works
The problem is that the dam game dont think he is connected I think, here is it was it says on "Optiopns" -> "Network"(se pic)
But om my PC, it sayd XWIS Server something, dont rembemer
(If i misunderstand you, dont blame me, i am no english speaker)
At the same time? Together, in the same game?
With an original version of the game? TFD or not?
When you said "with same IP adress", did you mean a routed network with the router carrying the WAN IP, as I assumed, or do these machines actually use the same LAN IP?
Are both able to connect to other internet services? _________________ #renproj:renegadeprojects.com via Matrix - direct link QUICK_EDIT
Renegade we are not using same IP(my bad), we are using same DNS, and smae connection, the IP looks almost the same, but still, WHY DOES IT NOT WORK?!?!?!? QUICK_EDIT
What are you trying to do?
1. Play RA2 online. (XWIS)
2. Play RA2 on a LAN.
1: If you are trying to play online with the same connection, the LAN Settings dialog has nothing to with it. Playing online with the same connection and the same CD-Key DOES NOT WORK.
2: If you are trying to play on a LAN, then all you have to do is select the correct Network Card in the LAN Settings dialog. For this to work under Windows XP, you must make sure that you LAN connection has the IPX Protocol installed. (Note: This protocol is NOT installed by default.)
Search online for tutorials on how to setup IPX in Windows XP.
A note to clear up the confusion in here: Gaffel thinks 'online' is LAN. It's the only reason he'd show the LAN Settings. @Gaffel, "online" is not LAN. Your LAN does not have a DNS. What you need, is an IPX tutorial. LAN games with both clients using the same CD-Key do function properly. _________________
That's impossible. No configuration would ever allow it. No OS allows it either.
That is basically what I ment...if he had set both computers to the same IP manually, and then tried to connect stuff, nothing would have worked - explaining his problems...
But since, obviously, online == LAN and IP == network card ID for him, I'm not actually surprised he fucked it all up. That's what happens when people have no idea what they're doing. (Coincidently, that's also the reason we have Microsoft Windows and religions.)
Now, back to Falaffel:
First of all, notice how IcySon55, too, tells you playing with the same CD-key ain't possible. (Just for the record.) Then, you should get this godforsaken "gamespy arcade" out of your head. You can either play online, via XWIS, or LAN, via standard IPX protocolled network multiplayer². Forget everything else. Then turn your brain on and think very hard about what you are trying to do: Are these two computers you want to use locally connected in some kind of way? (Hub, Switch, Router, WLAN AP?) Do you want only these two computers to take part in the game? Then you want network, LAN multiplayer, not "online". Or is the second computer you want to play with somewhere else, not in close proximity to you, or you want other people to be able to join, too? Then you want internet, XWIS, "online" multiplayer.
Think about which one you want. Long. Then think again and make sure you thought correctly. Then tell us what you want and what you did exactly to achieve it. Then we might be able to help you.
And then, when everything is set up, smash your computer(s) into pieces 'cause we were right all along, and you can't play with only one CD-key.
Oh, and quit the angry routine. It ain't the internet's fault you have no idea what you're doing.
² Technically, he could also play LAN online via VPN, but, come on...he can't even get an actual LAN to run... _________________ #renproj:renegadeprojects.com via Matrix - direct link QUICK_EDIT
Forget this lan thing and play online with same cd key(we are not using same but still dont work).
I deleted my account to create a new one, and with the new account, i could not connect to the "Custom Match" servers, the error messege sayd that I am not connected, have all this to do with accounts and WW? How about someone of you try this QUICK_EDIT
How about you actually do what we say if you want our help?
- First of all, "Forget this lan thing and play online with same cd key." is not an answer to my question, but actually an imperative. So the only thing I can say to that is "No, why should I?".
- Then, you obviously experience the same error with two entirely independent accounts, and still try to blame it on the account system, even though...
- ...the accounts work fine in what they should do (hold your data), and the error is actually related to your connection. But hey, it's totally normal for server-side saved accounts to interfere with your internet connection, isn't it? </sarcasm>
- Also, you again display a total lack of understanding of what you are actually doing - Westwood has been dead for years. Despite the fact that the claim Westwood might be jamming your connection is totally ridiculous, it would be absolutely impossible for them to do that - they don't exist anymore and they do not operate the online servers. Olaf and the Strike Team do. And, believe me, they've got better things to do than disconnecting some random n00b from the server.
- "How about someone of you try this" - yes. Smart idea. How about we test whether or not we get disconnected when using your internet connection? *shakes head* Since you seem to be kinda slow in the head, I'll spell it out for you: Either it's a general problem, then no user was able to play on XWIS for two days, which I assume has been noticed by now, or it is only you, in which case our report "no problems for me" helps you nothing.
From what I interpreted out of your crazy ADD gibberish so far, for some reason, your connection to XWIS gets disrupted. You can either answer my/our questions, and we can all try to fix it, or you can continue posting your bullshit, and will never be able to play online again. Your choice. But don't think we'll spend the rest of the week sitting here and waiting for you to help us help you.
Let us help you now, or let us be in peace. No middle way. _________________ #renproj:renegadeprojects.com via Matrix - direct link Last edited by Renegade on Tue Nov 07, 2006 7:53 pm; edited 1 time in total QUICK_EDIT
Thank for trying to help Renegade, but it suddenly started to work, me and my brother can play on XWIS server now with the same cd key, the problem was not me, it was XWIS, sorry about the topic but i did not know that until now QUICK_EDIT
