The time now is Thu Apr 25, 2024 12:20 am
Tactics VS CPU's or Humans Discuss them here!
Moderators: Global Moderators, Offtopic Moderators
PostPosted: Sat Feb 25, 2006 9:48 pm    Post subject:  Tactics VS CPU's or Humans Discuss them here! Reply with quote  Mark this post and the followings unread
This is where we can argue about what kind of tactics and stratagies work best and when to use them I'm starting off
Air Superority Is Key
Protect you base with a multitude of SAMS it takes aprx. 7 to take down an unmodded Orca fighter and if playing as gdi build a firestorm defense Its crititcle.
once defenses are up build up an air force. make sure you have 1 helipad for each aircraft unless u expect casuelties then you can build extra. in generals if you know a nuke or other super weapon is used on your airfields you can send them to your allies' airfields they will get rearmed and repaired and most of all survive!
An air attack is simple use long range artilary to knock out perimiter SAMs and then rush the base with bombers and fighters to take out units and criticle structures but don't get greedy just acomplish the objective and pull out. if you know how coardinate your aircraft in waves that are close enough to lend a helping hand but far enough away not to waste ordinence  on another wave's mission.
you may now reply.
[ Time: 0.1393s ][ Queries: 11 (0.0081s) ][ Debug on ]
